---千年难欲的怪问题哦(这个PCB问题让我头痛)!!![注意][求助]-->silverwol
我怀疑是在设置层时,去掉了layer-25层,有这个可能吗?我想重新把25层加进来,怎么加呢?????急!!!!!!!!! |
选择Cookie的保留时间:
登陆论坛信息保留时间,在这个时间内重复登陆论坛不需要重新登陆 |
我把地层设置为Split/Mixe后,执行Plane Area画出了自己需要的接地区(AGND,GND);但一执行FLOOD命令,就弹出如下的therm对话框呢(灌不了铜)?
我怀疑花孔和焊盘的孔径不对!经过N次的修改,我还是失败了!请高手大哥教教我!给我指点一下哦!在下感谢之极!
therm对话框:
THERMAL RELIEF ERRORS REPORT -- Untitled -- Tue Dec 09 09:39:49 2003
Drilled pads with Nondrilled pads with
less than 50% thermal extensions less than 100% thermal extensions
Report of Thermal Spokes Generator.
On Layer 2:
(14980, 13150) # = 0
(11650, 8120) # = 0
(11510, 9555) # = 0
U15.3 (15940, 12430) # = 0
U14.2 (17510, 12440) # = 0
J12.1 (19470, 12810) # = 0
(10848, 10347) # = 0
(11912, 9507) # = 0
C32.2 (15200, 12490) # = 0
C21.2 (19040, 12780) # = 0
(17970, 12780) # = 0
D23.A (16950, 13010) # = 0
(11996, 8550) # = 0
(17120, 13195) # = 0
(11992, 9922) # = 0
C31.2 (16980, 12590) # = 0
(11900, 8170) # = 0
SW2.2 (15440, 13180) # = 0
R68.1 (18085, 12980) # = 0
(17970, 12980) # = 0
Total Drilled pads: 19 Total Nondrilled pads: 1[em27][em27] |
选择Cookie的保留时间:
