如何让struts2和servlet的共存(1)
虽然现在大多数的项目都采用了 sturts2的架构,但是不可避免的有时候要跟旧项目模块的servlet合并共存。
但是我们会发现 当servlet单独存在时,采用<form name="form1" method="post" action="MessagesAction?action=loginRoom">时可以跳转运行的。
加入到sturts2架构后,会报错:
HTTP Status 404 - There is no Action mapped for namespace / and action nameMessagesAction
因为struts2会拦截一切来自浏览器的请求。struts2把servlet当成action了,因为servlet和action都是没有后缀的.
解决方法目前有四种:
方法1-给servlet加后缀
   统一在servlet后面加上.servlet结尾(包括web.xml配置文件中和页面上使用servlet的地方)
  比如我以上的例子:
index.jsp
<form name="form1" method="post" action="MessagesAction.servlet?action=loginRoom">
MessagesAction.java  不变
    package com.cheney.chat;
    import java.io.File;
    import java.io.FileOutputStream;
    import java.io.IOException;
    import java.io.PrintWriter;
    import java.text.DateFormat;
    import java.text.SimpleDateFormat;
    import java.util.Date;
    import java.util.Iterator;
    import java.util.Random;
    import java.util.Vector;
    import javax.servlet.ServletException;
    import javax.servlet.http.HttpServlet;
    import javax.servlet.http.HttpServletRequest;
    import javax.servlet.http.HttpServletResponse;
    import javax.servlet.http.HttpSession;
    import org.jdom.Document;
    import org.jdom.Element;
    import org.jdom.JDOMException;
    import org.jdom.input.SAXBuilder;
    import org.jdom.output.Format;
    import org.jdom.output.XMLOutputter;
    public class MessagesAction extends HttpServlet {
         * Constructor of the object.
        public MessagesAction() {
            super();
         * Destruction of the servlet. <br>
        public void destroy() {
            super.destroy(); // Just puts "destroy" string in log
            // Put your code here
         * The doGet method of the servlet. <br>
         * This method is called when a form has its tag value method equals to get.
         * @param request the request send by the client to the server
         * @param response the response send by the server to the client
         * @throws ServletException if an error occurred
         * @throws IOException if an error occurred
        public void doGet(HttpServletRequest request, HttpServletResponse response)
                throws ServletException, IOException {
            doPost(request, response);
         * Initialization of the servlet. <br>
         * @throws ServletException if an error occurs
        public void init() throws ServletException {
web.xml
      <servlet>
        <description>This is the description of my J2EE component</description>
        <display-name>This is the display name of my J2EE component</display-name>
        <servlet-name>MessagesAction</servlet-name>
        <servlet-class>com.cheney.chat.MessagesAction</servlet-class>
      </servlet>
      <servlet-mapping>
        <url-pattern>/MessagesAction.servlet</url-pattern>
      </servlet-mapping>
