如何让struts2和servlet的共存(3)
方法4-写一个过滤器区分sturst2和servlet
     自定义filter对servlet进行过滤:
# 该类是定义了一个过滤器(随便你放在哪个包下面),当既用到struts2有用到servlet时,
# 必须用该过滤器对所有的servlet做一次过滤,否则servlet将无法正常运行。
# 同时在web.xml中,在定义struts的核心控制器的过滤器前面添加该过滤器,添加代码如下:
* <filter>
*   <filter-name>redisp</filter-name>
*   <filter-class>filters.ReDispatcherFilter(该过滤器的类名)</filter-class>
*   <init-param>
*    <param-name>includeServlets</param-name>
*    <param-value>所配置的servlet,注意是那url-pattern</param-value>
*   </init-param>
* </filter>
* <filter-mapping>
*   <url-pattern>/*</url-pattern>
* </filter-mapping>
*该类也可以直接继承StrutsPrepareAndExecuteFilter的
    public class ReDispatcherFilter implements Filter {
    public void destroy() {
       // TODO Auto-generated method stub
    public void doFilter(ServletRequest req, ServletResponse resp,
        FilterChain chain) throws IOException, ServletException
       HttpServletRequest request = (HttpServletRequest)req;
       String target = request.getRequestURI();
       target = target.lastIndexOf("?")>0
     ?target.substring(target.lastIndexOf("/")+1,target.lastIndexOf("?")-target.lastIndexOf("/"))
          :target.substring(target.lastIndexOf("/")+1);
       System.out.println(target);
       if(this.includes.contains(target))
        RequestDispatcher rdsp = request.getRequestDispatcher(target);
        System.out.println("go..............."+rdsp);
        rdsp.forward(req, resp);
       else
        chain.doFilter(req, resp);
    private ArrayList<String> includes = new ArrayList<String>();
    public void init(FilterConfig config) throws ServletException {
       this.includes.addAll( Arrays.asList(config.getInitParameter("includeServlets").split(",")));
怕大家还是配置错误,给一个web.xml的配置实例。
     <filter>
            <filter-class>
    com.xheditor.servlet.ReDispatcherFilter</filter-class>
            <init-param>
                <param-value>UploadFileServlet</param-value>
               </init-param>
         </filter>
        <filter-mapping>
        </filter-mapping>
    <!-- struts2拦截页面请求的配置 -->
       <filter>
            <filter-name>struts2</filter-name>
            <filter-class>org.apache.struts2.dispatcher.FilterDispatcher</filter-class>
        </filter>
        <filter-mapping>
        </filter-mapping>
        <!-- servlet的配置 -->
        <servlet>
            <servlet-name>ImageServlet</servlet-name>
            <servlet-class>com.servlets.ImageServlet
            </servlet-class>
        </servlet>
        <servlet-mapping>
            <url-pattern>/myImageServlet/*</url-pattern>
        </servlet-mapping>
