STM32使用fsmc控制NOR flash 例程(7)
/* Read back NOR memory and check content correctness */
for (Index = 0x00; (Index < BUFFER_SIZE) && (WriteReadStatus == 0); Index++)
if (RxBuffer[Index] != TxBuffer[Index])
WriteReadStatus = Index + 1;
} if (WriteReadStatus == 0)
{ /* OK */
/* Turn on LD1 */
GPIO_SetBits(GPIOF, GPIO_Pin_6);
else
{ /* KO */
/* Turn on LD2 */
GPIO_SetBits(GPIOF, GPIO_Pin_7);
while (1)
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
void RCC_Configuration(void)
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
* Function Name : NVIC_Configuration
* Description : Configures Vector Table base location.
* Input : None
* Output : None
* Return : None
void NVIC_Configuration(void)
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function name : Fill_Buffer
* Description : Fill the global buffer
* Input : - pBuffer: pointer on the Buffer to fill
* - BufferSize: size of the buffer to fill
* - Offset: first value to fill on the Buffer
* Output param : None
void Fill_Buffer(u16 *pBuffer, u16 BufferLenght, u32 Offset)
u16 IndexTmp = 0;
/* Put in global buffer same values */
for (IndexTmp = 0; IndexTmp < BufferLenght; IndexTmp++ )
pBuffer[IndexTmp] = IndexTmp + Offset;
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d/r/n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/ |
