java格林尼治时间等转成常规日期类型字符串(2)
Mask Description
d Day of the month as digits; no leading zero for single-digit days.
dd Day of the month as digits; leading zero for single-digit days.
ddd Day of the week as a three-letter abbreviation.
dddd Day of the week as its full name.
m Month as digits; no leading zero for single-digit months.
mm Month as digits; leading zero for single-digit months.
mmm Month as a three-letter abbreviation.
mmmm Month as its full name.
yy Year as last two digits; leading zero for years less than 10.
yyyy Year represented by four digits.
h Hours; no leading zero for single-digit hours (12-hour clock).
hh Hours; leading zero for single-digit hours (12-hour clock).
H Hours; no leading zero for single-digit hours (24-hour clock).
HH Hours; leading zero for single-digit hours (24-hour clock).
M Minutes; no leading zero for single-digit minutes.
Uppercase M unlike CF timeFormat's m to avoid conflict with months.
MM Minutes; leading zero for single-digit minutes.
Uppercase MM unlike CF timeFormat's mm to avoid conflict with months.
s Seconds; no leading zero for single-digit seconds.
ss Seconds; leading zero for single-digit seconds.
l or L Milliseconds. l gives 3 digits. L gives 2 digits.
t Lowercase, single-character time marker string: a or p.
No equivalent in CF.
tt Lowercase, two-character time marker string: am or pm.
T Uppercase, single-character time marker string: A or P.
Uppercase T unlike CF's t to allow for user-specified casing.
TT Uppercase, two-character time marker string: AM or PM.
Uppercase TT unlike CF's tt to allow for user-specified casing.
Z US timezone abbreviation, e.g. EST or MDT. With non-US timezones or in the Opera browser, the GMT/UTC offset is returned, e.g. GMT-0500
o GMT/UTC timezone offset, e.g. -0500 or +0230.
S The date's ordinal suffix (st, nd, rd, or th). Works well with d.
'…' or "…" Literal character sequence. Surrounding quotes are removed.
UTC: Must be the first four characters of the mask. Converts the date from local time to UTC/GMT/Zulu time before applying the mask. The “UTC:” prefix is removed.
Name Mask Example
default ddd mmm dd yyyy HH:MM:ss Sat Jun 09 2007 17:46:21
shortDate m/d/yy 6/9/07
mediumDate mmm d, yyyy Jun 9, 2007
longDate mmmm d, yyyy June 9, 2007
fullDate dddd, mmmm d, yyyy Saturday, June 9, 2007
shortTime h:MM TT 5:46 PM
mediumTime h:MM:ss TT 5:46:21 PM
longTime h:MM:ss TT Z 5:46:21 PM EST
isoDate yyyy-mm-dd 2007-06-09
isoTime HH:MM:ss 17:46:21
isoDateTime yyyy-mm-dd'T'HH:MM:ss 2007-06-09T17:46:21
isoUtcDateTime UTC:yyyy-mm-dd'T'HH:MM:ss'Z' 2007-06-09T22:46:21Z
格林尼治时间转化详解:
首先 Mon Dec 09 22:06:24 格林尼治标准时间+0800 2013 字段一个格林尼治标准时间时间,一般情况下字段中不会含有中文,对于这种格式有两种解决方法
1剔除中文字符串
public static String convertGMTToLoacale(String gmt){
String cc = gmt.substring(0, 19) + gmt.substring(33, 38);
SimpleDateFormat sdf = new SimpleDateFormat("EEE MMM dd HH:mm:ss yyyy",new Locale("English"));
try {
Date date = sdf.parse(cc);
SimpleDateFormat dateformat = new SimpleDateFormat("dd/MM");
String result = dateformat.format(date);
return result;
} catch (ParseException e) {
return "";
2.第二种方法是在不进行字符串剔除的情况下:
在simpleDateFormat方法中将格式字符串变换为:"EEE MMM dd HH:mm:ss 格林尼治标准时间+0800 yyyy" 就可以了。这样就可一将时间转换为Date类型:
private DateFormat format = new SimpleDateFormat("EEE MMM dd HH:mm:ss 格林尼治标准时间+0800 yyyy",Locale.ENGLISH);
3.第三种方法:
String str = "Wed Jun 5 00:00:00 GMT+08:00 2013";//在08与00之间加:
java.text.SimpleDateFormat sdf = new SimpleDateFormat("E MMM dd HH:mm:ss z yyyy",Locale.US);
System.out.println(sdf.format(new Date()));
Date d;
try {
d = sdf.parse(str);
sdf = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
System.out.println(sdf.format(d));
// TODO Auto-generated catch block
e.printStackTrace();
4.第四种方法:
long d2 = Date.parse("Fri Aug 15 08:00:37 CST 2014");
Date datetime=new Date(d2);
System.out.println(datetime.toLocaleString()); |
