基于STM32 I2C的TMP101温度传感器的C源码(3)
TM 报警极性.POL 也是报警的 咱先不管.....
这个STM32 历程没有借助DMA 与中断。
#include "STM32Lib\\stm32f10x.h"
#include "hal.h"
u8 I2c_Buf[3]="AB0";//温度存放
void I2C_Configuration(void)
I2C_InitTypeDef I2C_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE); //开I2C的时钟
/* PB6,7 SCL and SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; // 开漏复用功能
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_DeInit(I2C1);
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C; //设置I2C为I2C模式
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2; //I2C快速模式Tlow / Thigh = 2 就是拉扯SCL 高低电平比
I2C_InitStructure.I2C_OwnAddress1 = 0x30; //STM32自身地址
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable; //使能应答(ACK)
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; //应答7位地址
I2C_InitStructure.I2C_ClockSpeed = 100000; //100K速度
I2C_Cmd(I2C1, ENABLE);
I2C_Init(I2C1, &I2C_InitStructure);
/*允许1字节1应答模式*/
I2C_AcknowledgeConfig(I2C1, ENABLE);
**函数名:I2C_ReadTmp
**功能:读取tmp101的2个字节温度
void I2C_ReadTmp(void)
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)); /*检测总线是否忙 就是看 SCL 或SDA是否为 低 */
/*允许1字节1应答模式*/
/* 发送起始位 */
I2C_GenerateSTART(I2C1, ENABLE);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); /*EV5,主模式*/
/*发送器件地址(写)*/
I2C_Send7bitAddress(I2C1, 0x92, I2C_Direction_Transmitter);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
/*发送Pointer Register*/
I2C_SendData(I2C1, 0X00);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); /*数据已发送*/
/*起始位*/
/*发送器件地址(读)*/
I2C_Send7bitAddress(I2C1, 0x92, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
/* 读Temperature Register*/
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED)); /* EV7 */
I2c_Buf[0]= I2C_ReceiveData(I2C1);
I2C_AcknowledgeConfig(I2C1, DISABLE); //最后一位后要关闭应答的
I2C_GenerateSTOP(I2C1, ENABLE); //发送停止位
/*● 为了在收到最后一个字节后产生一个NACK脉冲,在读倒数第二个数据字节之后(在倒数第二个RxNE事件之后)必须清除ACK位。
● 为了产生一个停止/重起始条件,软件必须在读倒数第二个数据字节之后(在倒数第二个RxNE事件之后)设置STOP/START位。
● 只接收一个字节时,刚好在EV6之后(EV6_1时,清除ADDR之后)要关闭应答和停止条件的产生位。*/
I2c_Buf[1]= I2C_ReceiveData(I2C1);
/* Decrement the read bytes counter */
/*再次允许应答模式*/
**函数名:void I2C_InitTmp(void)
**功能:初始化TMP101
/* 发送器件地址(写)*/
I2C_Send7bitAddress(I2C1, 0X92, I2C_Direction_Transmitter);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2C1, 0X01);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
/* 写Configuration Register 12位温度 连续转换*/
I2C_SendData(I2C1, 0XFE);
//测试用 使用之前要先调用I2C_InitTmp 初始化TMP101
void I2C_Test(void)
char a[8]=" ";
u32 temp;
float tmp;
I2C_ReadTmp(); //读温度
temp=I2c_Buf[0]; //转换温度
temp=temp<<4;
temp=temp|I2c_Buf[1]>>4;
tmp=(temp/16.0); /*仅处理了正的温度 负温度取反后加1 再按正温度处理*/
a[0]=(char)tmp/10+48;
a[1]=(char)tmp%10+48;
a[2]='.';
a[3]=(char)((int)(tmp*10)%10+48);
a[4]=(char)((int)(tmp*100)%10+48);
a[5]=(char)((int)(tmp*1000)%10+48);
a[6]='C';
USART1_Puts(a); //USART 出温度
USART1_Puts("\r\n");
