STM32 FSMC总线深入研究(3)
STM32 FSMC总线深入研究(3)
以下是FSMC-SRAM模式下的初始化代码,分享的同时,希望对你有用。
/* Private typedef -----------------------------------------------------------*/typedef struct{  vu16 LCD_REG;  vu16 LCD_RAM;} LCD_TypeDef;#define    LCD_WriteCmd(cmd)    LCD->LCD_REG = cmd#define    LCD_WriteData(data)    LCD->LCD_RAM = data/* LCD is connected to the FSMC_Bank1_NOR/SRAM4 and NE4 is used as ship select signal */#define LCD_BASE    ((u32)(0x60000000 | 0x0C000000))#define LCD         ((LCD_TypeDef *) LCD_BASE)void LCD_FSMCConfig(void){      FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;  FSMC_NORSRAMTimingInitTypeDef  p;/*-- FSMC Configuration ------------------------------------------------------*//*----------------------- SRAM Bank 4 ----------------------------------------*/  /* FSMC_Bank1_NORSRAM4 configuration */    //标准//     p.FSMC_AddressSetupTime = 1;//     p.FSMC_AddressHoldTime = 2;//     p.FSMC_DataSetupTime = 2;    //     p.FSMC_BusTurnAroundDuration = 1;//     p.FSMC_CLKDivision = 1;//     p.FSMC_DataLatency = 2;        //超快  p.FSMC_AddressSetupTime = 0;  p.FSMC_AddressHoldTime = 0;  p.FSMC_DataSetupTime = 1;      p.FSMC_BusTurnAroundDuration = 0;  p.FSMC_CLKDivision = 0;  p.FSMC_DataLatency = 0;        p.FSMC_AccessMode = FSMC_AccessMode_A;  /* Color LCD configuration ------------------------------------     LCD configured as follow:        - Data/Address MUX = Disable        - Memory Type = SRAM        - Data Width = 16bit        - Write Operation = Enable        - Extended Mode = Enable        - Asynchronous Wait = Disable */  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;    //2.0  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);    /* BANK 4 (of NOR/SRAM Bank 1~4) is enabled */  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);}
继承事业,薪火相传
