本人初学,遇到菜鸟问题,请教大侠 这是一个除法程序 .title "asm test" .global START .sect "init" Num16 .set 0x0009h Den16 .set 0x0003h .text START: MOVU ACC, @ Num16 MOV PH, @ Den16 RPT #16 ||SUBCU ACC,@PH MOV T,@AH SB START, UNC 编译时总是提示: "asmtest.asm", ERROR! at line 6: [E0002] Invalid mnemonic specification Num16 .set 0x0009h "asmtest.asm", ERROR! at line 7: [E0002] Invalid mnemonic specification Den16 .set 0x0003h "asmtest.asm", ERROR! at EOF: [E0300] The following symbols are undefined: 3 Assembly Errors, No Assembly Warnings Num16 Den16 Errors in Source - Assembler Aborted >> Compilation failure 这么写有什么问题啊??谢谢各位 |
