马弗炉pdf文档可能在WAP端浏览体验不佳。建议您优先选择TXT,或下载源文件到本机查看。
LABORATORY FURNACES
BOX FURNACES TUBE FURNACES CRUCIBLE FURNACES CONTROLLERS HOT PLATES
Analyze
Detect
Measure
Control?
Lindberg/Blue M Furnaces
Box Furnaces
The Lindberg/Blue M product line offers a versatile selection of small, medium and large chamber box furnaces suitable for a variety of industrial and laboratory applications. Advanced engineering and specialized construction techniques include variable density insulation, double shell cabinets, long-life heating elements and vertical, horizontal side swing or swing down doors. 1100°C Moldatherm? Box Furnaces . . . . . . . . . . . . . . . . . . . .4-5 1200°C LGO? Box Furnaces . . . . . . . . . . . . . . . . . . . .6-7 1200°C Box Furnaces, Heavy-Duty . . . . . . . . . . . . . . . . . . . . .8-9 1500°C Box Furnaces, Multi-Purpose, Integral Control . . . . . . . . . . 灵的博格productPDF_31132. . . . . . . . .10 1500°C Box Furnace, HeavyDuty, Independent Control . . . . . . . . . .11 1700°C Box Furnace, Independent Control . . . . . . . . . . . .12-13 1700°C Box Furnace, Large Chamber, Integral Control . . . . . . . . . . . . . . . .14-15
Tube Furnaces
Applications for Lindberg/Blue M Tube Furnaces include high temperature air and atmosphere processes in horizontal or vertical con?gurations. Single and three-zone designs create precise temperature uniformity. Temperature controllers offer a range of sophistication, including microprocessor-based single and multi-setpoint programmable controls. Mini-Mite? 1100°C Tube Furnace, Single Zone . . . . . . . . . . . .16-17 1100°C Tube Furnaces, Three Zone . . . . . . . . . . . . . . . . . . . .18-19 1200°C Split-Hinge Tube Furnaces . . . . . . . . . . . . . . . . . . . . . .20-23 1500°C Tube Furnace, Heavy-Duty, Independent Control . . . . . . . . . . . . . . . . . . . . . . .24-26 1500°C Tube Furnace, General Purpose, Integral Control . . . . . . . . . . . . . 马弗炉. . . . . .27 1700°C Tube Furnaces, High Temperature, Independent Control . . . . . . . . . . . . . . . . . . . . . . .28-29
Crucible Furnaces
Lindberg/Blue M Crucible Furnaces create safe, energy ef?cient, high temperature performance for melting, sintering, annealing and atmosphere processing. Microprocessor-based independent control systems assure accuracy and repeatability. 1200°C Crucible Furnace, Top Loading . . . . . . . . . . . . . . . . . . .30-31 1700°C Crucible Furnace, Top or Bottom Loading . . . . . . . . . . . . . .32-33
Hot Plates
Lindberg/Blue M Hot Plates provide large surface heating up to 400°C for general purpose applications. 400°C Hot Plate, Solid-State Control . . . . . . . . . . . . . . . .34 400°C Hot Plate, 3-Switch On/Off Control . . . . . . . . . . . .34
Controllers and Accessories
Controllers and Accessories . . . . . . . . . .35
2
Some questions to consider when selecting a Lindberg/Blue M furnace for your application
1. What temperature is needed for the application?
Lindburg/Blue M furnaces are listed by increasing maximum temperatur相关阅读:
马弗炉 北京 100083
马弗炉
本文来自:http://www.hnliangreyi.com/,转载请注明出处。 |
