java中spring 框架 中的action操作(extends ActionSupport) 一般配置在struts中 通过 浏览器 通过链接形式访问
例如:我的action和配置文件如下:
RapToDpsProjectRaw.java
package com.action.rap;
public class RapToDpsProjectRaw extends ActionSupport {
private static final long serialVersionUID = 4759438181190004544L;
private DpsProjectRapReposity dpsProjectRapReposity;
public void setDpsProjectRapReposity(
DpsProjectRapReposity dpsProjectRapReposity) {
this.dpsProjectRapReposity = dpsProjectRapReposity;
public String execute() {
System.out.println("已执行");
return SUCCESS;
rap.xml spring文件
<?xml version="1.0" encoding="GBK"?>
<!-- 指定Spring配置文件的Schema信息 -->
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="http://www.springframework.org/schema/p"
xsi:schemaLocation="http://www.springframework.org/schema/beans
http://www.springframework.org/schema/beans/spring-beans-3.0.xsd">
<!-- 查询LINKURL -->
<bean id="rapToDpsProjectRaw" class="com.action.rap.RapToDpsProjectRaw">
<property name="dpsProjectRapReposity" ref="dpsProjectRapReposity"></property>
</bean>
</beans>
rap.xml struts文件
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE struts PUBLIC
"-//Apache Software Foundation//DTD Struts Configuration 2.1.7//EN"
"http://struts.apache.org/dtds/struts-2.1.7.dtd">
<struts>
<package name="rapToDpsProjectRaw" extends="imoen-default" namespace="/rap">
<action name="rapToDpsProjectRaw" class="rapToDpsProjectRaw">
<result type="json"></result>
</action>
</package>
</struts>
我要执行这个action 就会在浏览器中输入 http://localhost:8080/项目名/rap/rapToDpsProjectRaw
如果要在 main方式中 运行 主要是获取到 rapToDpsProjectRaw这个Bean 代码如下:
public static void main(final String[] args) {
LOG.info("starting to copy record from rap system to mongo db...");
final String[] paths = new String[] {
"resource/spring/action/rap/rap.xml",
"resource/struts/rap.xml", "resource/spring/common-beans.xml",
"resource/spring/reposity/common-reposity.xml" };
@SuppressWarnings("resource")
final ApplicationContext context = new FileSystemXmlApplicationContext(
paths); // ClassPathXmlApplicationContext
final RapToDpsProjectRaw processor = (RapToDpsProjectRaw) context
.getBean("rapToDpsProjectRaw");
final String result = processor.execute();
if (ActionSupport.SUCCESS.equals(result)) {
LOG.info("Good job, copy operation succedded!");
} else {
LOG.warn("Oops! There's something wrong under the hook!");
LOG.info("finished copying record from rap system to mongo db.");
