httpclient常用基本抓取类(3)
private String doGet(String url, String encode)
            throws ClientProtocolException, IOException {
        String result = "";
        try {
            HttpGet httpRequst = new HttpGet(url);
            // httpRequst.addHeader("Content-Type", "text/html;charset=" +
            // encode);
            // httpRequst.getParams().setParameter(
            // CoreProtocolPNames.HTTP_CONTENT_CHARSET, encode);
            DefaultHttpClient httpClient = new DefaultHttpClient();
            // httpClient.getParams().setParameter(
                    CoreConnectionPNames.CONNECTION_TIMEOUT, 8000);// 连接时间20s
                    CoreConnectionPNames.SO_TIMEOUT, 8000);// 数据传输时间60s
            HttpResponse httpResponse = httpClient.execute(httpRequst);// 其中HttpGet是HttpUriRequst的子类
            if (httpResponse.getStatusLine().getStatusCode() == 200) {
                HttpEntity httpEntity = httpResponse.getEntity();
                if (httpEntity.getContentEncoding() != null) {
                    if ("gzip".equalsIgnoreCase(httpEntity.getContentEncoding()
                            .getValue())) {
                        httpEntity = new GzipDecompressingEntity(httpEntity);
                    } else if ("deflate".equalsIgnoreCase(httpEntity
                            .getContentEncoding().getValue())) {
                        httpEntity = new DeflateDecompressingEntity(httpEntity);
                result = enCodetoString(httpEntity, encode);// 取出应答字符串
            } else
                httpRequst.abort();
        } catch (ClientProtocolException e) {
            System.out.println("doget代理读取超时");
        } catch (IOException e) {
        return result;
    private String doGetByGoagent(String url, String encode)
        String result = "";
        httpRequst.addHeader("Accept-Encoding", "gzip,deflate,sdch");
        HttpHost proxyHost = new HttpHost("127.0.0.1", 8087, null);
        httpClient.getParams().setParameter(CoreConnectionPNames.SO_TIMEOUT,
                6000);// 数据传输时间60s
        httpClient.getParams().setParameter(ConnRouteParams.DEFAULT_PROXY,
                proxyHost);
                        .getValue())) {
        } else
            httpRequst.abort();
        return result;
