httpclient模拟登录(2)
httpclient模拟登录(2)
模拟登录完整示例
    package crawl;
    import java.io.BufferedReader;
    import java.io.BufferedWriter;
    import java.io.File;
    import java.io.FileOutputStream;
    import java.io.FileReader;
    import java.io.FileWriter;
    import java.io.IOException;
    import java.io.InputStream;
    import java.io.InputStreamReader;
    import java.io.Reader;
    import java.io.UnsupportedEncodingException;
    import java.net.URL;
    import java.net.URLConnection;
    import java.nio.charset.Charset;
    import java.nio.charset.UnsupportedCharsetException;
    import org.apache.http.Header;
    import org.apache.http.HttpEntity;
    import org.apache.http.HttpResponse;
    import org.apache.http.ParseException;
    import org.apache.http.client.ClientProtocolException;
    import org.apache.http.client.entity.DeflateDecompressingEntity;
    import org.apache.http.client.entity.GzipDecompressingEntity;
    import org.apache.http.client.methods.HttpGet;
    import org.apache.http.client.methods.HttpPost;
    import org.apache.http.entity.StringEntity;
    import org.apache.http.impl.client.DefaultHttpClient;
    import org.apache.http.params.CoreConnectionPNames;
    import org.apache.http.params.CoreProtocolPNames;
    import org.apache.http.protocol.HTTP;
    import org.apache.http.util.CharArrayBuffer;
    import org.springframework.context.ApplicationContext;
    import org.springframework.context.support.FileSystemXmlApplicationContext;
    public abstract class LoginTianyan {
        private static String encode = "utf-8";
        protected static ApplicationContext loadSpringBean() {
            final String[] paths = new String[] {
                    "resource/spring/action/action.xml",
                    "resource/struts/action.xml",
                    "resource/spring/common-beans.xml",
                    "resource/spring/reposity/mongoBean.xml" };
            final ApplicationContext context = new FileSystemXmlApplicationContext(
                    paths); // ClassPathXmlApplicationContext
            return context;
        protected static Boolean loginTianyan(DefaultHttpClient httpPostClient)
                throws UnsupportedEncodingException, IOException,
                ClientProtocolException {
            String parm = "username=joe%40163.com&password=123&redirect=&source_flow=&__source_node__=start&__context__=5ufhX2NDkiv0BqBT8aCbOZPPNjFLVRRGcuKVOAe-RxaZmPooKR5xIOOhqkdGM-7J-eWrCqmPh0pI2LjZ0h68b21up5kKMTkFjQuOvs_pmB5i2rn-2V2v60mfp9HeKJCp6_a-QV2cL4GD1H81gR7JRA%3D%3D&__form__=login&redirect=&button=Sign+In";
            HttpPost httpRequst = new HttpPost(
                    "https://www.Tianyan.com/user/signin/");// 创建HttpPost对象
            StringEntity entity = new StringEntity(parm);
            httpRequst.setEntity(entity);
            httpRequst.getParams().setParameter(
                    CoreProtocolPNames.HTTP_CONTENT_CHARSET, encode);
            httpPostClient.getParams().setParameter(
                    CoreConnectionPNames.CONNECTION_TIMEOUT, 20000);// 连接时间20s
                    CoreConnectionPNames.SO_TIMEOUT, 20000);// 数据传输时间60s
            HttpResponse httpResponse = httpPostClient.execute(httpRequst);// 其中HttpGet是HttpUriRequst的子类
            if (httpResponse.getStatusLine().getStatusCode() == 200) {
                HttpEntity httpEntity = httpResponse.getEntity();
                if (httpEntity.getContentEncoding() != null) {
                    if ("gzip".equalsIgnoreCase(httpEntity.getContentEncoding()
                            .getValue())) {
                        httpEntity = new GzipDecompressingEntity(httpEntity);
                    } else if ("deflate".equalsIgnoreCase(httpEntity
                            .getContentEncoding().getValue())) {
                        httpEntity = new DeflateDecompressingEntity(httpEntity);
                String result = enCodetoString(httpEntity, encode);// 取出应答字符串
                System.out.println(result);
            } else if (httpResponse.getStatusLine().getStatusCode() == 302) {
                System.out.println("重定向了");
                Header header = httpResponse.getFirstHeader("location");
                if (header != null) {
                    String urlString = header.getValue();
                    System.out.println("header中的value " + urlString);
                    if (!urlString.contains("www")) {
                        urlString = "https://www.tianyan.com" + urlString;
                    if (urlString != null && !urlString.equals("")) {
                        String resultS = getUrlContent(httpPostClient, urlString);
                        if (!resultS.equals("")) {
                            return true;
            return false;
        private static String getUrlContent(DefaultHttpClient httpPostClient,
                String urlString) throws IOException, ClientProtocolException {
            HttpGet httpGet = new HttpGet(urlString);
            HttpResponse httpGetResponse = httpPostClient.execute(httpGet);// 其中HttpGet是HttpUriRequst的子类
                    CoreConnectionPNames.CONNECTION_TIMEOUT, 10000);// 连接时间20s
                    CoreConnectionPNames.SO_TIMEOUT, 8000);// 数据传输时间60s
            if (httpGetResponse.getStatusLine().getStatusCode() == 200) {
                HttpEntity httpEntity = httpGetResponse.getEntity();
                            .getValue())) {
                // System.out.println(result);
                return result;
            return "";
        public static String enCodetoString(final HttpEntity entity,
                final String defaultCharset) throws IOException, ParseException {
            return enCodetoStringDo(entity,
                    defaultCharset != null ? Charset.forName(defaultCharset) : null);
        public static String enCodetoStringDo(final HttpEntity entity,
                Charset defaultCharset) throws IOException, ParseException {
            if (entity == null) {
                throw new IllegalArgumentException("HTTP entity may not be null");
            InputStream instream = entity.getContent();
            if (instream == null) {
                return null;
            try {
                if (entity.getContentLength() > Integer.MAX_VALUE) {
                            "HTTP entity too large to be buffered in memory");
                int i = (int) entity.getContentLength();
                if (i < 0) {
                    i = 4096;
                Charset charset = null;
                try {
                    // ContentType contentType = ContentType.get(entity);
                    // if (contentType != null) {
                    // charset = contentType.getCharset();
                } catch (final UnsupportedCharsetException ex) {
                    throw new UnsupportedEncodingException(ex.getMessage());
                if (charset == null) {
                    charset = defaultCharset;
                    charset = HTTP.DEF_CONTENT_CHARSET;
                Reader reader = new InputStreamReader(instream, charset);
                CharArrayBuffer buffer = new CharArrayBuffer(i);
                char[] tmp = new char[1024];
                int l;
                while ((l = reader.read(tmp)) != -1) {
                    buffer.append(tmp, 0, l);
                return buffer.toString();
            } finally {
                instream.close();
