httpclient模拟登录(3)
httpclient模拟登录(3)
     * @Description: TODO
     * @param @param 硬盘名
     * @param @param 文件名
     * @param @param 文件夹名
     * @param @param 保存后缀名
     * @param @param 保存的内容
     * @return void
     * @throws
     * @author joe
     * @date 2015-3-6
    public static void writeToFile(String topName, String fileName,
            String tagName, String type, String content) {
        File dirFile = null;
        try {
            dirFile = new File(topName + ":\\" + tagName);
            if (!(dirFile.exists()) && !(dirFile.isDirectory())) {
                boolean creadok = dirFile.mkdirs();
                if (creadok) {
                    System.out.println(" ok:创建文件夹成功! ");
                } else {
                    System.out.println(" err:创建文件夹失败! ");
        } catch (Exception e) {
            e.printStackTrace();
        String fullPath = dirFile + "/" + fileName + "." + type;
        write(fullPath, content);
     * 写文件
     * @param path
     * @param content
    public static boolean write(String path, String content) {
        String s = new String();
        String s1 = new String();
        BufferedWriter output = null;
        try {
            File f = new File(path);
            if (f.exists()) {
            } else {
                System.out.println("文件不存在,正在创建...");
                if (f.createNewFile()) {
                    System.out.println("文件创建成功!");
                } else {
                    System.out.println("文件创建失败!");
            BufferedReader input = new BufferedReader(new FileReader(f));
            while ((s = input.readLine()) != null) {
                s1 += s + "\n";
            System.out.println("原文件内容:" + s1);
            input.close();
            s1 += content;
            output = new BufferedWriter(new FileWriter(f));
            output.write(s1);
            output.flush();
            return true;
            return false;
        } finally {
            if (output != null) {
                try {
                    output.close();
                } catch (IOException e) {
     * @param @param fileUrl文件链接
     * @param @param topName硬盘名
     * @param @param fileName文件名
     * @param @param tagName文件夹名
     * @param @param type 后缀名
     * @return void
     * @throws
     * @author joe
     * @date 2015-3-6
    public static void downLoadFile(String fileUrl, String topName, String fileName,
            String tagName, String type) {
        // 下载网络文件
        int bytesum = 0;
        int byteread = 0;
        try {
            System.out.println("开始下载"+fileUrl);
            URL url = new URL(fileUrl);
            URLConnection conn = url.openConnection();
            InputStream inStream = conn.getInputStream();
            File fileD = new File(topName + ":/" + tagName);
            // 如果文件夹不存在则创建
            if (!fileD.exists() && !fileD.isDirectory()) {
                System.out.println("正在新建目录");
                fileD.mkdirs();
            } else {
                System.out.println("目录存在");
            File file = new File(topName + ":/" + tagName + "/" + fileName
                    + "." + type);
            if (!file.exists()) {
                try {
                    file.createNewFile();
                    // TODO Auto-generated catch block
            FileOutputStream fs = new FileOutputStream(topName + ":/" + tagName
                    + "/" + fileName + "." + type);
            byte[] buffer = new byte[1204];
            while ((byteread = inStream.read(buffer)) != -1) {
                bytesum += byteread;
                System.out.println(bytesum);
                fs.write(buffer, 0, byteread);
            System.out.println("downloaded ok");
