httpclient常用基本抓取类(5)
@SuppressWarnings("unused")
    private String postByCompanyProxy(String url, String parm, String encode)
            throws ClientProtocolException, IOException {
        int count = 5;
        String result = "";
        String urlString = url;
        boolean okProxy = false;
        boolean newProxy = false;
        int oldProxyUsecount = 0;
        for (int i = 0; i <= count; i++) {
            try {
                if (newProxy || oldProxyUsecount > 2 || ip.equals("")) {
                    okProxy = postByCompanyProxyBoolean(url, parm, encode);
                if (okProxy) {
                    System.out.println("正在使用代理" + ip + ":" + port);
                    HttpPost httpRequst = new HttpPost(url);// 创建HttpPost对象
                    StringEntity entity = new StringEntity(parm);
                    entity.setContentType("application/x-www-form-urlencoded");
                    httpRequst.setEntity(entity);
                    httpRequst.getParams().setParameter(
                            CoreProtocolPNames.HTTP_CONTENT_CHARSET, encode);
                    HttpResponse httpResponse = httpPostClient
                            .execute(httpRequst);// 其中HttpGet是HttpUriRequst的子类
                    if (httpResponse.getStatusLine().getStatusCode() == 200) {
                        HttpEntity httpEntity = httpResponse.getEntity();
                        if (httpEntity.getContentEncoding() != null) {
                            if ("gzip".equalsIgnoreCase(httpEntity
                                    .getContentEncoding().getValue())) {
                                httpEntity = new GzipDecompressingEntity(
                                        httpEntity);
                            } else if ("deflate".equalsIgnoreCase(httpEntity
                                httpEntity = new DeflateDecompressingEntity(
                                        httpEntity);
                        result = enCodetoString(httpEntity, encode);// 取出应答字符串
                        // System.out.println(result);
                        if (resultTest(result)) {
                            return result;
                        } else if (result.contains("function JumpSelf")
                                && result.contains("WebShieldSessionVerify")) {
                            int indexs = result
                                    .indexOf("&WebShieldSessionVerify");
                            int indexe = result.indexOf("\";}</script>");
                            String verify = result.substring(indexs, indexe);
                            urlString = urlString + verify;
                            newProxy = false;
                                && !result.contains("WebShieldSessionVerify")) {
                            urlString = url;
                            newProxy = false;
                    } else if (httpResponse.getStatusLine().getStatusCode() == 302) {
                        System.out.println("重定向了");
                        Header header = httpResponse.getFirstHeader("location");
                        if (header != null) {
                            urlString = header.getValue();
                            System.out.println(urlString);
                            if (urlString.contains("tabid=26")) {
                                urlString = "http://www.landchina.com"
                                        + urlString;
                                result = getByHttpClient(urlString, encode,
                                        httpPostClient);
                                    System.out.println(i + "公司代理成功抓取" + url);
                                    return result;
                                newProxy = false;
                            newProxy = false;
                    } else {
                        httpRequst.abort();
                } else {
                    oldProxyUsecount++;
            } catch (ClientProtocolException e) {
                newProxy = true;
                System.out.println(ip + "代理ip拒绝了");
            } catch (IOException e) {
                oldProxyUsecount++;
                System.out.println(ip + "代理读取超时");
        return "";
