读写SPI FLASH--驱动部分(10)
static int erase_4K_sector(unsigned int idx)
    uint32_t addr;
    uint32_t word, var, val;
    if(((idx+1)<< SPI_FLASH_SECTOR_BIT) > SPI_FLASH_SIZE)
        return (1);
     /* disable flash protection */
    if(is_flash_protection())
        if(!disable_flash_protection())
            SPI_ERR("can't disable flash protection/n");
            return (0);
    addr = idx<<SPI_FLASH_SECTOR_BIT;
    writel(addr, (void*)(spi_char.mem_virt+SPI_ADDR));
    word = readw((void *)(spi_char.mem_virt+SPI_CTRL));
    word |= SPI_CTRL_SCGO; /* set cycle */
    word |= SPI_CTRL_ACS; /* Enable Atomic Cycle Sequence */
    word &= ~SPI_CTRL_SPOP;
    word &= ~SPI_CTRL_COP;
    word = word | SPI_CTRL_OPMENU_4KERASE<<SPI_CTRL_COP_SHIFT; /* write */
    word &= ~SPI_CTRL_DBC;
    word = word | 0x00<<SPI_CTRL_DBC_SHIFT; /* write count=1 */
    word &= ~SPI_CTRL_DC;
     /* check the status */
     val = readw((void *)(spi_char.mem_virt+SPI_STATUS));
     while(val & SPI_STATUS_SCIP)
         val = readw((void *)(spi_char.mem_virt+SPI_STATUS));/* check the status */
     writew(word, (void *)(spi_char.mem_virt+SPI_CTRL));
     word = readw((void *)(spi_char.mem_virt+SPI_STATUS));
     word |= SPI_STATUS_CDS; /* clear Cycle Done Status flag */
     word |= SPI_STATUS_BAS;  /* clear blocked flag */
     writew(word, (void *)(spi_char.mem_virt+SPI_STATUS));
     SPI_DBG("spi_4kerase end/n");
    return (1);
继承事业,薪火相传
