[求助]仿真时的问题
[求助]仿真时的问题
程序调试时遇到这个问题:首先#define LED PTB_PTB7 ;然后在main中定义ddrb,使PTB7为输出管脚,最后LED = 1; 如果应用软件仿真,运行到LED = 1时,程序就停止在这里,调试信息显示,访问了无效或没有初始化的地址。但是如果在ICS板上调试仿真,程序能够正常往下运行,请问问题出在哪里呢?
把你的project打包发过来看看吧。
海纳百川  有容乃大
[公告]
我的同學說這個是軟件的设置,是因為地址没有初始化。他說這個问题使用手冊上有敘述o[em23]
下面是程序的全部,在project向导中仅仅选用软件仿真。 #include /* for EnableInterrupts macro */ #include /* include peripheral declarations */ typedef unsigned char UCHAR; typedef unsigned int UINT; #define LED1 PTB_PTB7 #define LED2 PTB_PTB6 #define LED3 PTB_PTB5 #define RESET PTB_PTB4 #define SHIFT PTB_PTB3 #define LATCH PTB_PTB2 #define A PTB_PTB0 UCHAR near ADResult, ADCEnd = 0; UCHAR near LED1Buf = 0,LED2Buf = 0,LED3Buf = 0; void interrupt 16 ADC(void){ ADCEnd = 1; ADResult = ADR; } void ShowLED(UCHAR LEDBuf, UCHAR LEDNum){ /*************************** -- -- -- | | | | | | -- -- -- | | | | | | -- -- . -- 1 2 3 ****************************/ UCHAR near LEDTemp, i, ConverValue; RESET = 0; SHIFT = 0; LATCH = 0; RESET = 1; switch (LEDBuf) { case 0: ConverValue = 0xFC; break; case 1: ConverValue = 0x60; break; case 2: ConverValue = 0xDA; break; case 3: ConverValue = 0xF2; break; case 4: ConverValue = 0x66; break; case 5: ConverValue = 0xB6; break; case 6: ConverValue = 0xBE; break; case 7: ConverValue = 0xE0; break; case 8: ConverValue = 0xFE; break; case 9: ConverValue = 0xF6; break; } if(LEDNum == 2){ ConverValue |= 0x01; } for(i = 0; i < 8; i++){ SHIFT = 0; LEDTemp = 0x7F | ConverValue; LEDBuf <<= 1; if(LEDTemp == 0xFF){ A = 1; }else{ A = 0; } SHIFT = 1; } LATCH = 1; if(LEDNum == 1){ LED1 = 0; LED2 = 1; LED3 = 1; }else if(LEDNum == 2){ LED1 = 1; LED2 = 0; LED3 = 1; }else{ LED1 = 1; LED2 = 1; LED3 = 0; } } void ShowConvert(void){ volatile unsigned int near TrueValue ; TrueValue =(UINT) (ADResult * 314.7) / 255; TrueValue = TrueValue ; LED1Buf = (UCHAR)(TrueValue/100); LED2Buf = (UCHAR)((TrueValue - LED1Buf * 100)/10); LED3Buf = (UCHAR)(TrueValue - LED1Buf * 100 - LED2Buf *10); } void Wait6ms(void){ UCHAR near Temp; TMODH = 0x2; TMODL = 0x58; TSC = 0x05; do{ __asm nop; }while(TSC_TOF == 0); Temp = TSC; TSC_TOF = 0; TSC_TSTOP = 1; } void main(void) { UCHAR near i; EnableInterrupts; /* enable interrupts */ CONFIG2 = 0x00; CONFIG1 = 0x38; DDRB = 0xFF; DDRA = 0x18; ADICLK = 0x40; //ADSCR = 0x41; PTA_PTA4 = 1; RESET = 0; LED1 = 1; LED2 = 1; LED3 = 1; /* include your code here */ for(;;) { __RESET_WATCHDOG(); /* feeds the dog */ ADSCR = 0x41; do{ __asm nop; }while(ADCEnd == 0); ADCEnd = 0; ShowConvert(); for(i = 0; i < 50; i++){ ShowLED(LED1Buf,1); __RESET_WATCHDOG(); Wait6ms(); ShowLED(LED2Buf,2); __RESET_WATCHDOG(); Wait6ms(); ShowLED(LED3Buf,3); __RESET_WATCHDOG(); Wait6ms(); } } /* loop forever */ /* please make sure that you never leave this function */ }
请问如何解决呢?在哪个文档中有叙述呢
软件仿真时出现的“无效或没有初始化的地址”,一般是指输入口的数据未初始化而去读引起的。从你的软件上看好象没有。是不是没写全呢?你把输入口的数据先赋值,再RUN就不会出错了!
学后而问
连同学们也懂回答的问题,最好不要胡乱要别人把project打包给你,最好先想一想!
用的是什么芯片?
海纳百川  有容乃大
使用的是68hc908qy4
还是将整个PROJECT打包发过来吧,这样效率最高:
strongchenfree@yahoo.com.cn
海纳百川  有容乃大
