基于群星ARM的lwIP以太网中断分析(2)
[c-sharp] view plaincopy
  • * This function should be called when a packet is ready to be read
  • * from the interface. It uses the function low_level_input() that
  • * should handle the actual reception of bytes from the network
  • * interface. Then the type of the received packet is determined and
  • * the appropriate input function is called.
  • * 当一个数据包已经从接口处读取时,调用本函数.它使用    low_level_input()函
  •    数处理从网络接口接收的实际字节.然后根据接收的数据包确定并调用适当的input函数.
  • * @param netif the lwip network interface structure for this ethernetif
  • int
  • stellarisif_input(struct netif *netif)
  •   struct ethernetif *ethernetif;
  •   struct pbuf *p;
  •   int count = 0;
  •   ethernetif = netif->state;
  •   /* move received packet into a new pbuf */
  •   //从一个pbuf数据包队列中弹出一个pbuf数据包
  •   while((p = dequeue_packet(ðernetif->rxq)) != NULL) {
  •     count++;
  •     /* process the packet.处理数据包 */
  •     if (ethernet_input(p, netif)!=ERR_OK) {
  •       LWIP_DEBUGF(NETIF_DEBUG, ("stellarisif_input: input error/n"));
  •       pbuf_free(p);
  •       p = NULL;
  •   return(count);
继承事业,薪火相传
