指定maven的目录路径(4)
指定maven的目录路径(4)
<dependency>
                <groupId>javax.servlet</groupId>
                <artifactId>servlet-api</artifactId>
                <version>2.5</version>
                <scope>provided</scope>
            </dependency>
            <dependency>
                <groupId>javax.servlet.jsp</groupId>
                <artifactId>jsp-api</artifactId>
                <version>2.1</version>
            </dependency>
            <dependency>
                <groupId>org.mortbay.jetty</groupId>
                <artifactId>servlet-api-2.5</artifactId>
                <version>6.1.14</version>
            </dependency>
            <dependency>
                <artifactId>jsp-2.1</artifactId>
            </dependency>
            <dependency>
                <artifactId>jsp-api-2.1</artifactId>
            </dependency>
            <dependency>
                <groupId>org.springframework</groupId>
                <artifactId>spring-web</artifactId>
                <version>4.0.0.RELEASE</version>
            </dependency>
            <dependency>
                <groupId>org.quartz-scheduler</groupId>
                <artifactId>quartz</artifactId>
                <version>2.2.1</version>
            </dependency>
            <dependency>
                <groupId>org.slf4j</groupId>
                <artifactId>slf4j-api</artifactId>
                <version>1.6.6</version>
            </dependency>
            <dependency>
                <artifactId>slf4j-log4j12</artifactId>
                <version>1.7.5</version>
            </dependency>
            <dependency>
                <groupId>log4j</groupId>
                <artifactId>log4j</artifactId>
                <version>1.2.17</version>
            </dependency>
            <dependency>
                <artifactId>quartz-jobs</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-context-support</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-tx</artifactId>
            </dependency>
             <dependency>
                <groupId>org.apache.struts</groupId>
                <artifactId>struts2-core</artifactId>
                <version>2.3.16.3</version>
                <scope>runtime</scope>
            </dependency>
            <dependency>
                <artifactId>struts2-json-plugin</artifactId>
            </dependency>
             <dependency>
                <groupId>org.apache.struts.xwork</groupId>
                <artifactId>xwork-core</artifactId>
                <version>2.3.16</version>
            </dependency>
                <dependency>
                <artifactId>struts2-spring-plugin</artifactId>
                <version>2.3.15.1</version>
                 <exclusions>
                    <exclusion>
                <artifactId>spring-beans</artifactId>
                    </exclusion>
                     <exclusion>
                    </exclusion>
                     <exclusion>
                <artifactId>spring-core</artifactId>
                    </exclusion>
                     <exclusion>
                <artifactId>spring-context</artifactId>
                    </exclusion>
                </exclusions>
            </dependency>
                <dependency>
                    <groupId>org.apache.httpcomponents</groupId>
                    <artifactId>httpclient</artifactId>
                    <version>4.2.5</version>
                </dependency>
                <dependency>
                    <groupId>tomcat</groupId>
                    <artifactId>jasper-compiler</artifactId>
                    <version>5.5.23</version>
                </dependency>
                <dependency>
                    <artifactId>jasper-runtime</artifactId>
                </dependency>
        </dependencies>
        <reporting>
            <plugins>
                <plugin>
                    <groupId>org.apache.maven.plugins</groupId>
                    <artifactId>maven-surefire-plugin</artifactId>
                    <version>2.17</version>
                </plugin>
                <plugin>
                    <groupId>org.codehaus.mojo</groupId>
                    <artifactId>findbugs-maven-plugin</artifactId>
                    <version>2.5.5</version>
                    <configuration>
                        <findbugsXmlOutput>true</findbugsXmlOutput>
                        <findbugsXmlWithMessages>true</findbugsXmlWithMessages>
                        <xmlOutput>true</xmlOutput>
                    </configuration>
                </plugin>
                <plugin>
                    <artifactId>maven-checkstyle-plugin</artifactId>
                    <version>2.13</version>
                    <configuration>
                        <configLocation>resource/checkstyle_checks.xml</configLocation>
                    </configuration>
                    <reportSets>
                        <reportSet>
                            <reports>
                                <report>checkstyle</report>
                            </reports>
                        </reportSet>
                    </reportSets>
                </plugin>
                <plugin>
                    <artifactId>maven-pmd-plugin</artifactId>
                    <version>3.2</version>
                </plugin>
            </plugins>
        </reporting>
        <packaging>war</packaging>
    </project>
