熬夜到了1点了,终于写出了1602的时钟计数器代码。为什么是时钟计数器呢?
因为我还没来得及做校准时间,所以只能称之为时钟计数器,不能成为电子钟。
网上很少用人公开这一类代码,一搜FPGA 1602,都是写一个静态的显示,在实际应用中,是没有用的,因此这个简单的例子,给大家抛砖引玉了!
上代码: Qii 9.0编译过,21EDA 开发板测试OK
module LCD
rst,
key1,
clk,
rw,
rs,
en,
data
input clk,rst,key1;
output rs,en,rw;
output [7:0] data;
reg rs,en_sel;
reg [7:0] data;
reg [7:0] shi,fen,miao;
reg [31:0]count,count1; //LCD CLK 分频计数器
reg lcd_clk;
reg [7:0] one_1,one_2,one_3,one_4,one_5,one_6,one_7,one_8,one_9,one_10,one_11,one_12,one_13,one_14,one_15,one_16;
reg [7:0] two_1,two_2,two_3,two_4,two_5,two_6,two_7,two_8,two_9,two_10,two_11,two_12,two_13,two_14,two_15,two_16;
reg [7:0] next,xianshi,two;
parameter state0 =8'h00, //设置8位格式,2行,5*7 8'h38;
state1 =8'h01, //整体显示,关光标,不闪烁 8'h0C 闪烁 8'h0e
state2 =8'h02, //设定输入方式,增量不移位 8'h06
state3 =8'h03, //清除显示 8'h01
state4 =8'h04, //显示第一行的指令 80H
state5 =8'h05, //显示第二行的指令 80H+40H
scan =8'h06,
nul =8'h07;
parameter data0 =8'h10, //2行,共32个数据
data1 =8'h11,
data2 =8'h12,
data3 =8'h13,
data4 =8'h14,
data5 =8'h15,
data6 =8'h16,
data7 =8'h17,
data8 =8'h18,
data9 =8'h19,
data10 =8'h20,
data11 =8'h21,
data12 =8'h22,
data13 =8'h23,
data14 =8'h24,
data15 =8'h25,
data16 =8'h26,
data17 =8'h27,
data18 =8'h28,
data19 =8'h29,
data20 =8'h30,
data21 =8'h31,
data22 =8'h32,
data23 =8'h33,
data24 =8'h34,
data25 =8'h35,
data26 =8'h36,
data27 =8'h37,
data28 =8'h38,
data29 =8'h39,
data30 =8'h40,
data31 =8'h41;
initial //初始值
begin
//第一行显示 TEL:13868160569
one_1<="T"; one_2<="E"; one_3<="L"; one_4<=":"; one_5<="1"; one_6<="3"; one_7<="8"; one_8<="6";
one_9<="8";one_10<="1";one_11<="6";one_12<="0";one_13<="5";one_14<="6";one_15<="9";one_16<=" ";
//第二行显示 Clock:00-00-00
two_1<="C"; two_2<="l"; two_3<="o"; two_4<="c"; two_5<="k"; two_6<=":"; two_7<=" "; two_8<=" ";
two_9<="-";two_10<=" ";two_11<=" ";two_12<="-";two_13<=" ";two_14<=" ";two_15<=" ";two_16<=" ";
shi<=0;fen<=0;miao<=0;
end
always @(posedge clk ) //获得LCD时钟
begin
count<=count+1;
if(count==250000)
begin
count<=0;
lcd_clk<=~lcd_clk;
end
end |
