java处理数据文本时间小函数积累(1)
统计某个字符在字符串中出现的次数
    public int Charcount(String string, String str) {
            int ii = 0;
            if (string == null)
                return 0;
            int[] count = new int[string.length()];
            // 将字符串中索引字符存在临时变量中
            char mid = str.charAt(0);
            for (int j = 0; j < count.length; j++) {
                char temp = string.charAt(j);
                if (mid == temp)
                    ii++;
            return ii;
时间字符串的比较
    public static int compare_date(String DATE1, String DATE2) {
            DateFormat df = new SimpleDateFormat("yyyy-MM-dd hh:mm");
            try {
            Date dt1 = df.parse(DATE1);
            Date dt2 = df.parse(DATE2);
            if (dt1.getTime() > dt2.getTime()) {
            System.out.println("dt1 在dt2后");
            return 1;
            } else if (dt1.getTime() < dt2.getTime()) {
            System.out.println("dt1在dt2前");
            return -1;
            } else {
            return 0;
            } catch (Exception exception) {
            exception.printStackTrace();
            return 0;
        public static void main(String args[]) {
            int i= compare_date("1995-11-12 15:21", "1999-12-11 09:59");
            System.out.println("i=="+i);
