java处理数据文本时间小函数积累(4)
面积单位的转化,把亩以及公顷转换成平方米
    private final static Pattern PATTERN_PRICE = Pattern
                .compile("(([0-9]+\\.[0-9]*[1-9][0-9]*)|([0-9]*[1-9][0-9]*\\.[0-9]+)|([0-9]*[1-9][0-9]*))");
    // 全部转换为平方米
        public float formatArea(String value) {
            Matcher matcher = PATTERN_PRICE.matcher(value);
            if (matcher.find()) {
                if (value.contains("亩") && !value.contains("平方米")){
                  return    String.format("%.2f",Float.parseFloat(matcher.group()) * 666.67);
                } else if (value.contains("公顷") && !value.contains("平方米")) {
                   return   String.format("%.2f",Float.parseFloat(matcher.group()) * 10000);
                } else if ((value.contains("亩") && value.contains("平方米"))||
                        (value.contains("公顷") && value.contains("平方米"))
                 return   formatMaxNumber(value);
                } else {
                 return  matcher.group();
            } else {
                grantarea.setUseValue("0.0");
            return grantarea;
    protected String formatMaxNumber(String value) {
            List<Float> fl = new ArrayList<Float>();
            if (value != null) {
                Matcher valueMatcher = intPattern.matcher(value);
                while (valueMatcher.find()) {
                    String strRjl = valueMatcher.group();
                    float rst = Float.valueOf(strRjl);
                    fl.add(rst);
                if (fl.size() == 1) {
                    return fl.get(0).toString();
                } else if (fl.size() == 2) {
                    if (fl.get(0) > fl.get(1)) {
                    } else {
                        return fl.get(1).toString();
            return null;
将中文日期转换为日期
        public static void main(String[] args) throws IOException {
            testConvertZwrq();
        private static void testConvertZwrq() {
            String[] list = new String[] { "二○○九年四月三十日", "○九年四月三十日", "二○○九年十二月三十一日", "二零零九年十二月三十一日" };
            for (String s : list) {
                Date d = convertCnDate(s);
                System.out.println(new SimpleDateFormat("yyyy-MM-dd").format(d));
        public static Date convertCnDate(String cprq) {
            int yearPos = cprq.indexOf("年");
            int monthPos = cprq.indexOf("月");
            String cnYear = cprq.substring(0, yearPos);
            String cnMonth = cprq.substring(yearPos + 1, monthPos);
            String cnDay = cprq.substring(monthPos + 1, cprq.length() - 1);
            String year = ConvertCnYear(cnYear);
            String month = ConvertCnDateNumber(cnMonth);
            String day = ConvertCnDateNumber(cnDay);
            Calendar c = Calendar.getInstance();
            c.set(Calendar.YEAR, Integer.parseInt(year));
            c.set(Calendar.MONTH, Integer.parseInt(month)-1);
            c.set(Calendar.DAY_OF_MONTH, Integer.parseInt(day));
            return c.getTime();
        private static String ConvertCnYear(String cnYear) {
            if(cnYear.length() == 2)
               return "20" + ConvertCnNumberChar(cnYear);
            else
                return ConvertCnNumberChar(cnYear);
        private static String ConvertCnDateNumber(String cnNumber) {
            if (cnNumber.length() == 1) {
                if(cnNumber.equals("十"))
                  return "10";
                else
                  return ConvertCnNumberChar(cnNumber);
            } else if (cnNumber.length() == 2) {
                if (cnNumber.startsWith("十")) {
                    return "1" + ConvertCnNumberChar(cnNumber.substring(1, 2));
                } else if (cnNumber.endsWith("十")) {
                    return ConvertCnNumberChar(cnNumber.substring(0, 1)) + "0";
                } else {
            } else if (cnNumber.length() == 3) {
                return ConvertCnNumberChar(cnNumber.substring(0, 1) + cnNumber.substring(2, 3));
            return null;
        private static String ConvertCnNumberChar(String cnNumberStr) {
            String ALL_CN_NUMBER = "○零一二三四五六七八九";
            String ALL_NUMBER = "00123456789";
            StringBuffer buf = new StringBuffer();
            for (int i = 0; i < cnNumberStr.length(); i++) {
                char c = cnNumberStr.charAt(i);
                int index = ALL_CN_NUMBER.indexOf(c);
                if (index != -1) {
                    buf.append(ALL_NUMBER.charAt(index));
                } else {
                    buf.append(cnNumberStr.charAt(i));
            return buf.toString();
