基于 AbstractQueuedSynchronizer 的并发类实现(1)
公平模式ReentrantLock实现原理前面的文章研究了AbstractQueuedSynchronizer的独占锁和共享锁,有了前两篇文章的基础,就可以乘胜追击,看一下基于AbstractQueuedSynchronizer的并发类是如何实现的。
ReentrantLock显然是一种独占锁,首先是公平模式的ReentrantLock,Sync是ReentractLock中的基础类,继承自AbstractQueuedSynchronizer,看一下代码实现:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
abstract static class Sync extends AbstractQueuedSynchronizer {
    private static final long serialVersionUID = -5179523762034025860L;
     * Performs {@link Lock#lock}. The main reason for subclassing
     * is to allow fast path for nonfair version.
    abstract void lock();
     * Performs non-fair tryLock.  tryAcquire is
     * implemented in subclasses, but both need nonfair
     * try for trylock method.
    final boolean nonfairTryAcquire(int acquires) {
        final Thread current = Thread.currentThread();
        int c = getState();
        if (c == 0) {
            if (compareAndSetState(0, acquires)) {
                setExclusiveOwnerThread(current);
                return true;
        else if (current == getExclusiveOwnerThread()) {
            int nextc = c + acquires;
            if (nextc < 0) // overflow
                throw new Error("Maximum lock count exceeded");
            setState(nextc);
            return true;
        return false;
    protected final boolean tryRelease(int releases) {
        int c = getState() - releases;
        if (Thread.currentThread() != getExclusiveOwnerThread())
            throw new IllegalMonitorStateException();
        boolean free = false;
        if (c == 0) {
            free = true;
            setExclusiveOwnerThread(null);
        setState(c);
        return free;
    protected final boolean isHeldExclusively() {
        // While we must in general read state before owner,
        // we don't need to do so to check if current thread is owner
        return getExclusiveOwnerThread() == Thread.currentThread();
    final ConditionObject newCondition() {
        return new ConditionObject();
    // Methods relayed from outer class
    final Thread getOwner() {
        return getState() == 0 ? null : getExclusiveOwnerThread();
    final int getHoldCount() {
        return isHeldExclusively() ? getState() : 0;
    final boolean isLocked() {
        return getState() != 0;
     * Reconstitutes this lock instance from a stream.
     * @param s the stream
    private void readObject(java.io.ObjectInputStream s)
        throws java.io.IOException, ClassNotFoundException {
        s.defaultReadObject();
        setState(0); // reset to unlocked state
Sync属于一个公共类,它是抽象的说明Sync会被继承,简单整理一下Sync主要做了哪些事(因为Sync不是ReentrantLock公平锁的关键):
  • 定义了一个lock方法让子类去实现,我们平时之所以能调用ReentrantLock的lock()方法,就是因为Sync定义了它
  • 实现了非公平锁tryAcquira的方法
  • 实现了tryRelease方法,比较简单,状态-1,独占锁的线程置空
  • 实现了isHeldExclusively方法
  • 定义了newCondition方法,让开发者可以利用Condition实现通知/等待
