java-spring与mongodb的整合方式一 手动注入xml
User.java
    package mongo;
    public class User {
        private String name;
        private String message;
        public String getName() {
            return name;
        public void setName(String name) {
            this.name = name;
        public String getMessage() {
            return message;
        public void setMessage(String message) {
            this.message = message;
Userservice.java
    package mongo;
    import java.util.List;
    import org.springframework.context.ApplicationContext;
    import org.springframework.context.support.FileSystemXmlApplicationContext;
    import org.springframework.data.mongodb.core.MongoTemplate;
    import org.springframework.data.mongodb.core.query.Criteria;
    import org.springframework.data.mongodb.core.query.Query;
    import org.springframework.data.mongodb.core.query.Update;
    import com.mongodb.DBCollection;
    import com.mongodb.DBCursor;
    import com.mongodb.MapReduceOutput;
    public class Userservice {
        private static String USERS_COLLECTION = "users";
        public static void main(String[] args) {
            ApplicationContext ctx = new FileSystemXmlApplicationContext(
                    "WEB-INF/mongoConfig.xml");
            MongoTemplate mongoTemplate = (MongoTemplate) ctx
                    .getBean("mongoTemplate");
            // 插入数据
    //         User user=new User();
    //         user.setName("zoe");
    //         user.setMessage("try insert");
    //         mongoTemplate.insert(user,USERS_COLLECTION);
    //         System.out.println("insert finish");
            // 查询
            // 查询全部
            // List<User> users=mongoTemplate.find(new Query(),
            // User.class,USERS_COLLECTION);
            // for(User a:users)
            // System.out.println(a.getName()+" "+a.getMessage());
            // 查询一个
            // User a = mongoTemplate.findOne(
            // new Query(Criteria.where("name").is("zoe")), User.class,
            // USERS_COLLECTION);
            // System.out.println(a.getName() + " " + a.getMessage());
            // 模糊查询
            // List<User> users = mongoTemplate.find(
            // new Query(new Criteria("name").regex(".*?" + "o" + ".*"))
            // .limit(9), User.class, USERS_COLLECTION);
            // for (User a : users) {
            // 修改
            // mongoTemplate
            // .updateFirst(new Query(Criteria.where("name").is("zoe")),
            // new Update().set("message", "update success"),
            // User b = mongoTemplate.findOne(
            // System.out.println(b.getName() + " " + b.getMessage());
            // 删除
    //        System.out.println(a);
    //        mongoTemplate.remove(new Query(Criteria.where("name").is("zoe")),
    //        System.out.println(b);
            //mapreduce 统计同名数量
            DBCollection coll = mongoTemplate.getCollection("users");
            String map = "function() { emit(this.name, {count:1});}";
            String reduce = "function(key, values) {var total = 0;for(var i=0;i<values.length;i++){total += values[i].count;}return {count:total};}";
            String result = "resultCollection";
            MapReduceOutput mapReduceOutput = coll.mapReduce(map,
                reduce.toString(), result, null);
            DBCollection resultColl = mapReduceOutput.getOutputCollection();
            DBCursor cursor = resultColl.find();
            while (cursor.hasNext()) {
              System.out.println(cursor.next());
