ADDAB (.unit) src2, src1, dst src1 is added to src2 using the byte addressing mode specified for src2. The addition defaults to linear mode. However, if src2 is one of A4−A7 or B4−B7, the mode can be changed to circular mode by writing the appropriate value to the AMR .The result is placed in dst. AMR: 1−0 A4 MODE 0−3h Address mode selection for register file A4. 0 Linear modification (default at reset) 1h Circular addressing using the BK0 field 2h Circular addressing using the BK1 field 3h Reserved ADDAB .D1 A4,A2,A4 ADDAB (.unit) src2, src1, dst src1 is added to src2 using the byte addressing mode specified for src2. The addition defaults to linear mode. However, if src2 is one of A4−A7 or B4−B7, the mode can be changed to circular mode by writing the appropriate value to the AMR .The result is placed in dst. AMR: 1−0 A4 MODE 0−3h Address mode selection for register file A4. 0 Linear modification (default at reset) 1h Circular addressing using the BK0 field 2h Circular addressing using the BK1 field 3h Reserved ADDAB .D1 A4,A2,A4 A2=0000000BH(A2[0-1]==3),src2==A4-->A4[0-1]=3,the mode changed...and the result is placed in dst(A4).in other words,if(src2==[A4-A7,B4-B7]){A4'[0-1]=A2[0-1];A4=A4';}
[此贴子已经被作者于2007-5-21 16:30:15编辑过] |
