- 来自
- 中国
在FPGA开发设计中,经常是多个时钟同时工作于同一模块中,不同时钟域的信号间要保证稳定通信,必须要处理好时序问题,也就是要充分考虑信号的建立和保持时间,以下是在设计中常用的单脉冲信号的处理方法:
`timescale 1 ps / 1 ps
module PULSE_GEN (
XRST , // (i) Reset Input ( Asynchronous )
CLK_I , // (i) Clock At Input Side
CLK_O , // (i) Clock At Output Side
PULSE_I , // (i) Pulse Input
PULSE_O // (o) Pulse Output
parameter P_TYPE = 8'd0 ;
// Declare the port directions
input XRST ; // (i) Reset Input ( Asynchronous )
input CLK_I ; // (i) Clock At Input Side
input CLK_O ; // (i) Clock At Output Side
input PULSE_I ; // (i) Pulse Input
output PULSE_O ; // (o) Pulse Output
// Internal signals define
reg r_PULSE_I ;
reg [2:0] r_PULSE_O ; // r_PULSE_O[0], r_pluse_o[1] Should Not Be Duplicated
// Synthesis Attribute MAX_FANOUT of r_PULSE_O is 9999;
// RTL Body
generate
if(P_TYPE == 0) begin :TYPE_0_PULSEGEN
// Input Pulse Keep ( CLK_I domain )
always @( posedge CLK_I or negedge XRST ) begin
if( !XRST ) begin
r_PULSE_I <= 1'b0 ;
end else begin
if ( PULSE_I == 1'b1 ) begin
r_PULSE_I <= ~r_PULSE_I ;
end
end
end
// Output Pulse Sync. And Generate ( CLK_O Domain )
always @( posedge CLK_O or negedge XRST ) begin
if( !XRST ) begin
r_PULSE_O <= 3'b000 ;
end else begin
r_PULSE_O <= { r_PULSE_O[1:0] , r_PULSE_I } ;
end
end
assign PULSE_O = (r_PULSE_O[2] != r_PULSE_O[1] ) ; // 0 -> 1
end
endgenerate
endmodule |
