Spring Boot配置MongoDB多数据源(1)
新建一个基础的抽象类
AbstractMongoConfigure.java
内容如下:
package com.biologic.util;
import org.springframework.data.mongodb.MongoDbFactory;
import org.springframework.data.mongodb.core.MongoTemplate;
import org.springframework.data.mongodb.core.SimpleMongoDbFactory;
import com.mongodb.MongoClient;
public abstract class AbstractMongoConfig {
// 变量名跟配置的参数对应
private String host, database, username, password;
private int port;
public String getHost() {
return host;
public void setHost(String host) {
this.host = host;
public String getDatabase() {
return database;
public void setDatabase(String database) {
this.database = database;
public String getUsername() {
return username;
public void setUsername(String username) {
this.username = username;
public String getPassword() {
return password;
public void setPassword(String password) {
this.password = password;
public int getPort() {
return port;
public void setPort(int port) {
this.port = port;
public MongoDbFactory mongoDbFactory() throws Exception {
// 无认证的初始化方法
return new SimpleMongoDbFactory(new MongoClient(host, port), database);
// 有认证的初始化方法
// ServerAddress serverAddress = new ServerAddress(host, port);
// List<MongoCredential> mongoCredentialList = new ArrayList<>();
// mongoCredentialList.add(MongoCredential.createCredential(username, database,
// password.toCharArray()));
// return new SimpleMongoDbFactory(new MongoClient(serverAddress,
// mongoCredentialList), database);
* Factory method to create the MongoTemplate
abstract public MongoTemplate getMongoTemplate() throws Exception;
或者
private String uri;
* Method that creates MongoDbFactory Common to both of the MongoDb
* connections
return new SimpleMongoDbFactory(new MongoClientURI(uri);
abstract public MongoTemplate getMongoTemplate() throws Exception; |
