专家回复:
在FIT 的属性里有:Macrocell Power Setting
XC9500/XL/XV CPLDs offer two macrocell power options - high speed and low power. By default, this property is set to standard (Std), which is High speed. If you select low power, the product terms feeding that macrocell will each be programmed with a low power bit. This reduces current consumption at the expense of additional time delay. For more information, see the product Data Sheets. |
