//#include "graphics.h"
#include "fcntl.h"
#include "stdio.h"
#define N 30
int hzk_p;
void open_hzk(void);
void get_mat(char hz_code[ ],unsigned char buff[ ]);
void creatclib(char *name);
void sort( );
void writeclib(char *name);
unsigned char bytes[32];
unsigned *point1[2];
struct hz_mat
unsigned incode;
unsigned char mat[32];
struct hzlib
{int n;
struct hz_mat lib[N];
}clib;
main( )
open_hzk( );
creatclib("hz.txt");
writeclib("mylib.h");
void creatclib(char *name )
register i,j,found,n;
FILE *fp;
n=0;
fp=fopen("li.txt","rt");
rewind(fp);
printf("%x ",fp);
if(fp==NULL)
printf("li.txt notexist!ENTER to system");
exit(1);
while(!feof(fp))
fread(point1,2,1,fp);
printf("%x %x",*point1,fp);
found=0;
for(i=0;i<N&&!found;i++)
if(clib.lib[i ].incode==*point1)
found=1;
if(!found)
clib.lib[n].incode=*point1;
get_mat(point1,bytes);
for(j=0;j<32;j++)
clib.lib[n].mat[j]=bytes[j];
n++;
clib.n=n;
fclose(fp);
sort( );
void open_hzk( )
hzk_p=open("c:\\windows\\command\\pdos95.bat",0);
printf("%x ",hzk_p);
if(hzk_p==-1)
printf("the hzk 16not exist!enter to system\n");
getch( );
exit(1);
{int i;
unsigned char qh,wh;
unsigned long offset;
qh=hz_code[0]-0xa0;
wh=hz_code[1]-0xa0;
offset=(94*(qh-1)+(wh-1))*32L;
lseek(hzk_p,offset,SEEK_SET);
read(hzk_p,buff,32);
FILE *fp;
int i,j;
fp=fopen(name,"w");
fprintf(fp,"struct hz_mat{\n");
fprintf(fp,"unsigned incode;\n");
fprintf(fp,"unsigned charmat[32];\n");
fprintf(fp,"};\n");
fprintf(fp,"struct hzlib{\n");
fprintf(fp,"int n;\n");
fprintf(fp,"struct hz_matlib[%d];\n",clib.n);
fprintf(fp,"}clib={%d,\n{\n",clib.n);
j=0;
while(j<clib.n)
fprintf(fp,"{0x%x,",clib.lib[j].incode);
for(i=0;i<32;i++)
fprintf(fp,"0x%x",(unsigned char )clib.lib[j].mat);
if(i!=31)
fprintf(fp,",");
if((i+1)%8==0&&i!=31)
fprintf(fp,"\n");
j++;
if(j!=clib.n)
fprintf(fp,"\n");
else
fprintf(fp,"}\n");
fprintf(fp,"}\n};\n");
fclose(fp);
void sort(void)
register int a,b,i,m;
unsigned t;
char buffer[32];
m=clib.n;
for(a=1;a<m;++a)
for(b=m-1;b>=a;--b)
if(clib.lib[b-1].incode>clib.lib[b ].incode)
t=clib.lib[b-1].incode;
clib.lib[b-1].incode=clib.lib[b ].incode;
clib.lib[b ].incode=t;
for(i=0;i<32;i++)
buffer[i ]=clib.lib[b-1].mat[ i];
clib.lib[b-1].mat[i ]=clib.lib[b ].mat[i ];
clib.lib[b ].mat[i ]=buffer[i ];
