应该只是大小不同,两者甚至可以互换,并都支持active serial configuration : With SRAM-based devices that support active serial configuration, configuration data must be reloaded each time the device powers up, the system reconfigures, or when new configuration data is required. Serial configuration devices are flash memory devices with a serial interface that can store configuration data for FPGA devices that support active serial configuration and reload the data to the device upon power-up or reconfiguration. Table 14–1 lists the serial configuration devices. Device Memory Size (Bits) EPCS1 1,048,576 EPCS4 4,194,304 EPCS16 16,777,216 EPCS64 67,108,864 EPCS128 134,217,728 Table 14–2. Serial Configuration Device Support for Stratix III Devices (Part 1 of 2)
For an 8-pin SOIC package, you can migrate vertically from the EPCS1 to the EPCS4 or EPCS16 devices since the EPCS devices are offered in the same device package. Similarly, for a 16-pin SOIC package, you can migrate vertically from the EPCS16 to the EPCS64 or EPCS128 devices.
参考:cyc_c51014.pdf
[此贴子已经被作者于2007-10-20 12:39:05编辑过] |
