聚类(7)
聚类(7)
TFIDFMeasure.cs
     * tf/idf implementation
     * Author: Thanh Dao, thanh.dao@gmx.net
    using System;
    using System.Collections;
    using System.Collections.Generic;
    using WawaSoft.Search.Common;
    namespace WawaSoft.Search.Common
        /// <summary>
        /// Summary description for TF_IDFLib.
        /// </summary>
        public class TFIDFMeasure
            private string[] _docs;
            private string[][] _ngramDoc;
            private int _numDocs=0;
            private int _numTerms=0;
            private ArrayList _terms;
            private int[][] _termFreq;
            private float[][] _termWeight;
            private int[] _maxTermFreq;
            private int[] _docFreq;
            ITokeniser _tokenizer = null;
            private IDictionary _wordsIndex=new Hashtable() ;
            public TFIDFMeasure(string[] documents,ITokeniser tokeniser)
                _docs=documents;
                _numDocs=documents.Length ;
                _tokenizer = tokeniser;
                MyInit();
            public int NumTerms
                get { return _numTerms; }
                set { _numTerms = value; }
            private void GeneratNgramText()
            private ArrayList GenerateTerms(string[] docs)
                ArrayList uniques=new ArrayList() ;
                _ngramDoc=new string[_numDocs][] ;
                for (int i=0; i < docs.Length ; i++)
                    IList<string> words=_tokenizer.Partition(docs);
                    for (int j=0; j < words.Count; j++)
                        if (!uniques.Contains(words[j]) )
                            uniques.Add(words[j]) ;
                return uniques;
            private static object AddElement(IDictionary collection, object key, object newValue)
                object element=collection[key];
                collection[key]=newValue;
                return element;
            private int GetTermIndex(string term)
                object index=_wordsIndex[term];
                if (index == null) return -1;
                return (int) index;
            private void MyInit()
                _terms=GenerateTerms (_docs );
                NumTerms=_terms.Count ;
                _maxTermFreq=new int[_numDocs] ;
                _docFreq=new int[NumTerms] ;
                _termFreq =new int[NumTerms][] ;
                _termWeight=new float[NumTerms][] ;
                for(int i=0; i < _terms.Count ; i++)
                    _termWeight=new float[_numDocs] ;
                    _termFreq=new int[_numDocs] ;
                    AddElement(_wordsIndex, _terms, i);
                GenerateTermFrequency ();
                GenerateTermWeight();
            private float Log(float num)
                return (float) Math.Log(num) ;//log2
            private void GenerateTermFrequency()
                for(int i=0; i < _numDocs  ; i++)
                    string curDoc=_docs;
                    IDictionary freq=GetWordFrequency(curDoc);
                    IDictionaryEnumerator enums=freq.GetEnumerator() ;
                    _maxTermFreq=int.MinValue ;
                    while (enums.MoveNext())
                        string word=(string)enums.Key;
                        int wordFreq=(int)enums.Value ;
                        int termIndex=GetTermIndex(word);
                        if(termIndex == -1)
                            continue;
                        _termFreq [termIndex]=wordFreq;
                        _docFreq[termIndex] ++;
                        if (wordFreq > _maxTermFreq) _maxTermFreq=wordFreq;
            private void GenerateTermWeight()
                for(int i=0; i < NumTerms   ; i++)
                    for(int j=0; j < _numDocs ; j++)
                        _termWeight[j]=ComputeTermWeight (i, j);
            private float GetTermFrequency(int term, int doc)
                int freq=_termFreq [term][doc];
                int maxfreq=_maxTermFreq[doc];
                return ( (float) freq/(float)maxfreq );
            private float GetInverseDocumentFrequency(int term)
                int df=_docFreq[term];
                return Log((float) (_numDocs) / (float) df );
            private float ComputeTermWeight(int term, int doc)
                float tf=GetTermFrequency (term, doc);
                float idf=GetInverseDocumentFrequency(term);
                return tf * idf;
            private  float[] GetTermVector(int doc)
                float[] w=new float[NumTerms] ;
                for (int i=0; i < NumTerms; i++)
                    w=_termWeight[doc];
                return w;
            public double [] GetTermVector2(int doc)
                double [] ret = new double[NumTerms];
                float[] w = GetTermVector(doc);
                for (int i = 0; i < ret.Length; i++ )
                    ret = w;
                return ret;
            public double GetSimilarity(int doc_i, int doc_j)
                double [] vector1=GetTermVector2 (doc_i);
                double [] vector2=GetTermVector2 (doc_j);
                return TermVector.ComputeCosineSimilarity(vector1, vector2) ;
            private IDictionary GetWordFrequency(string input)
                string convertedInput=input.ToLower() ;
                List<string> temp = new List<string>(_tokenizer.Partition(convertedInput));
                string[] words= temp.ToArray();
                Array.Sort(words);
                String[] distinctWords=GetDistinctWords(words);
                IDictionary result=new Hashtable();
                for (int i=0; i < distinctWords.Length; i++)
                    object tmp;
                    tmp=CountWords(distinctWords, words);
                    result[distinctWords]=tmp;
                return result;
            private static string[] GetDistinctWords(String[] input)
                if (input == null)
                    return new string[0];
                else
                    List<string> list = new List<string>();
                    for (int i=0; i < input.Length; i++)
                        if (!list.Contains(input)) // N-GRAM SIMILARITY?
                            list.Add(input);
                    return list.ToArray();
            private int CountWords(string word, string[] words)
                int itemIdx=Array.BinarySearch(words, word);
                if (itemIdx > 0)
                    while (itemIdx > 0 && words[itemIdx].Equals(word))
                        itemIdx--;
                int count=0;
                while (itemIdx < words.Length && itemIdx >= 0)
                    if (words[itemIdx].Equals(word)) count++;
                    itemIdx++;
                    if (itemIdx < words.Length)
                        if (!words[itemIdx].Equals(word)) break;
                return count;
