WawaKMeans.cs
using System;
namespace WawaSoft.Search.Common
public class WawaKMeans
/// <summary>
/// 数据的数量
/// </summary>
readonly int _coordCount;
/// <summary>
/// 原始数据
/// </summary>
readonly double[][] _coordinates;
/// <summary>
/// 聚类的数量
/// </summary>
readonly int _k;
/// <summary>
/// 聚类
/// </summary>
private readonly WawaCluster[] _clusters;
internal WawaCluster[] Clusters
get { return _clusters; }
/// <summary>
/// 定义一个变量用于记录和跟踪每个资料点属于哪个群聚类
/// _clusterAssignments[j]=i;// 表示第 j 个资料点对象属于第 i 个群聚类
/// </summary>
readonly int[] _clusterAssignments;
/// <summary>
/// 定义一个变量用于记录和跟踪每个资料点离聚类最近
/// </summary>
private readonly int[] _nearestCluster;
/// <summary>
/// 定义一个变量,来表示资料点到中心点的距离,
/// 其中—_distanceCache[i][j]表示第i个资料点到第j个群聚对象中心点的距离;
/// </summary>
private readonly double[,] _distanceCache;
/// <summary>
/// 用来初始化的随机种子
/// </summary>
private static readonly Random _rnd = new Random(1);
public WawaKMeans(double[][] data, int K)
_coordinates = data;
_coordCount = data.Length;
_k = K;
_clusters = new WawaCluster[K];
_clusterAssignments = new int[_coordCount];
_nearestCluster = new int[_coordCount];
_distanceCache = new double[_coordCount,data.Length];
InitRandom();
public void Start()
int iter = 0;
while (true)
Console.WriteLine("Iteration " + (iter++) + "...");
//1、重新计算每个聚类的均值
for (int i = 0; i < _k; i++)
_clusters[i].UpdateMean(_coordinates);
//2、计算每个数据和每个聚类中心的距离
for (int i = 0; i < _coordCount; i++)
for (int j = 0; j < _k; j++)
double dist = getDistance(_coordinates[i], _clusters[j].Mean);
_distanceCache[i,j] = dist;
//3、计算每个数据离哪个聚类最近
_nearestCluster[i] = nearestCluster(i);
//4、比较每个数据最近的聚类是否就是它所属的聚类
//如果全相等表示所有的点已经是最佳距离了,直接返回;
int k = 0;
if (_nearestCluster[i] == _clusterAssignments[i])
k++;
if (k == _coordCount)
break;
//5、否则需要重新调整资料点和群聚类的关系,调整完毕后再重新开始循环;
//需要修改每个聚类的成员和表示某个数据属于哪个聚类的变量
_clusters[j].CurrentMembership.Clear();
_clusters[_nearestCluster[i]].CurrentMembership.Add(i);
_clusterAssignments[i] = _nearestCluster[i];
/// <summary>
/// 计算某个数据离哪个聚类最近
/// </summary>
/// <param name="ndx"></param>
/// <returns></returns>
int nearestCluster(int ndx)
int nearest = -1;
double min = Double.MaxValue;
for (int c = 0; c < _k; c++)
double d = _distanceCache[ndx,c];
if (d < min)
min = d;
nearest = c;
if(nearest==-1)
return nearest;
/// <summary>
/// 计算某数据离某聚类中心的距离
/// </summary>
/// <param name="coord"></param>
/// <param name="center"></param>
static double getDistance(double[] coord, double[] center)
//int len = coord.Length;
//double sumSquared = 0.0;
//for (int i = 0; i < len; i++)
// double v = coord[i] - center[i];
// sumSquared += v * v; //平方差
//return Math.Sqrt(sumSquared);
//也可以用余弦夹角来计算某数据离某聚类中心的距离
return 1- TermVector.ComputeCosineSimilarity(coord, center);
/// <summary>
/// 随机初始化k个聚类
/// </summary>
private void InitRandom()
int temp = _rnd.Next(_coordCount);
_clusterAssignments[temp] = i; //记录第temp个资料属于第i个聚类
_clusters[i] = new WawaCluster(temp,_coordinates[temp]);
