基于Dubbo框架构建分布式服务(5)
基于Dubbo框架构建分布式服务(5)
  • ●服务消费方
服务消费方就容易了,只需要知道注册中心地址,并引用服务提供方提供的接口,消费方调用服务实现如下所示:
[url=][/url]
package org.shirdrn.dubbo.consumer;import java.util.Arrays;import java.util.List;import org.apache.commons.logging.Log;import org.apache.commons.logging.LogFactory;import org.shirdrn.dubbo.api.ChatRoomOnlineUserCounterService;import org.springframework.context.support.AbstractXmlApplicationContext;import org.springframework.context.support.ClassPathXmlApplicationContext;public class ChatRoomDubboConsumer {     private static final Log LOG = LogFactory.getLog(ChatRoomDubboConsumer.class);         public static void main(String[] args) throws Exception {          AbstractXmlApplicationContext context = new ClassPathXmlApplicationContext("classpath:consumer.xml");          try {               context.start();               ChatRoomOnlineUserCounterService chatRoomOnlineUserCounterService = (ChatRoomOnlineUserCounterService)
context.getBean("chatRoomOnlineUserCounterService");                        getMaxOnlineUserCount(chatRoomOnlineUserCounterService);                             getRealtimeOnlineUserCount(chatRoomOnlineUserCounterService);                             System.in.read();          } finally {               context.close();          }              }     private static void getMaxOnlineUserCount(ChatRoomOnlineUserCounterService liveRoomOnlineUserCountService) {          List<String> maxUserCounts = liveRoomOnlineUserCountService.getMaxOnlineUserCount(                    Arrays.asList(new String[] {"1482178010" , "1408492761", "1430546839",
"1412517075", "1435861734"}), "20150327", "yyyyMMdd");          LOG.info("After getMaxOnlineUserCount invoked: maxUserCounts= " + maxUserCounts);     }     private static void getRealtimeOnlineUserCount(ChatRoomOnlineUserCounterService liveRoomOnlineUserCountService)               throws InterruptedException {          String rooms = "1482178010,1408492761,1430546839,1412517075,1435861734";          String onlineUserCounts = liveRoomOnlineUserCountService.queryRoomUserCount(rooms);          LOG.info("After queryRoomUserCount invoked:color: #000000;"> onlineUserCounts);     }}[url=][/url]
对应的配置文件为consumer.xml,内容如下所示:
[url=][/url]
<?xml version="1.0" encoding="UTF-8"?><beans xmlns="http://www.springframework.org/schema/beans"     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:dubbo="http://code.alibabatech.com/schema/dubbo"     xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-3.0.xsd     http://code.alibabatech.com/schema/dubbo http://code.alibabatech.com/schema/dubbo/dubbo.xsd">     <dubbo:application name="chatroom-consumer" />     <dubbo:registry address="zookeeper://zk1:2181?backup=zk2:2181,zk3:2181" />         <dubbo:reference id="chatRoomOnlineUserCounterService" interface="org.shirdrn.dubbo.api.ChatRoomOnlineUserCounterService" version="1.0.0">          <dubbo:method name="queryRoomUserCount" retries="2" />     </dubbo:reference></beans>
[url=][/url]
也可以根据需要配置dubbo:reference相关的属性值,也可以配置dubbo:method指定调用的方法的配置信息,详细配置属性可以参考Dubbo官方文档。
