UART VHDL源程序-2
UART VHDL源程序-2
-- Transmit Shift Register:
Txshift:
    PROCESS (Reset, Txclk)
    BEGIN
IF Reset=''1'' THEN
     Txreg <= (OTHERS=>''0'') ;
     Txtag1 <= ''0'' ;
     Txtag2 <= ''0'' ;
            Txparity <= ''0'' ;
     Tx <= ''0'' ;
ELSIF Txclk''Event AND Txclk = ''1'' THEN
     IF (Txdone AND Txdatardy) = ''1''  THEN
         -- Initialize Registers And Load Next Byte Of Data
         Txreg    <= Txhold; -- Load Tx Register From Txhold
         Txtag2   <= ''1'';    -- Tag Bits For Detecting
         Txtag1   <= ''1'';    --    When Shifting Is Done
         Txparity <= ''1'';    -- Parity Bit.Initializing To 1==Odd Parity
         Tx       <= ''0'';    -- Start Bit
     ELSE
         -- Shift Data
         Txreg <= Txreg(1 TO 7) & Txtag1;
         Txtag1        <= Txtag2;
         Txtag2    <= ''0'';
         -- Form Parity As Each Bit Goes By
         Txparity      <= Txparity XOR Txreg(0);
         -- Shift Out Data Or Parity Bit Or Stop/Idle Bit
         IF Txdone = ''1'' THEN
      Tx <= ''1''; -- Stop/Idle Bit
         ELSIF Paritycycle = ''1'' THEN
      Tx <= Txparity; -- Parity Bit
         ELSE
          Tx <= Txreg(0); --Shift Data Bit
         END IF;
     END IF ;
END IF;
    END PROCESS;
    -- Paritycycle = 1 On Next To Last Cycle (When Txtag2 Has Reached Txreg(1))
    --   (Enables Putting The Parity Bit Out On Tx)
    Paritycycle <= Txreg(1) AND NOT (Txtag2 OR Txtag1 OR
         Txreg(7) OR Txreg(6) OR Txreg(5) OR
         Txreg(4) OR Txreg(3) OR Txreg(2));
    -- Txdone = 1 When Done Shifting (When Txtag2 Has Reached Tx)
    Txdone <= NOT (Txtag2 OR Txtag1 OR
    Txreg(7) OR Txreg(6) OR Txreg(5) OR Txreg(4) OR
    Txreg(3) OR Txreg(2) OR Txreg(1) OR Txreg(0));
Rx_proc:  -- Shift Data On Each Rxclk When Not Idling
    PROCESS (Reset, Rxclk)
    BEGIN
IF Reset=''1'' THEN
     Rxreg <= (OTHERS=>''0'') ;
            Rxparity <= ''0'' ;
            Paritygen <= ''0'' ;
            Rxstop <= ''0'' ;
ELSIF Rxclk''Event AND Rxclk = ''1'' THEN
     IF Rxidle = ''1'' THEN
         -- Load All Ones When Idling
         Rxreg <= (OTHERS=>''1'');
         Rxparity <= ''1'';
         Paritygen <= ''1''; -- Odd Parity
         Rxstop <= ''0'';
     ELSE
         -- Shift Data When Not Idling
         -- Bug In Assigning To Slices
         -- Rxreg (0 TO 6) <= Rxreg (1 TO 7);
         -- Rxreg(7) <= Rxparity;
         Rxreg <= Rxreg (1 TO 7) & Rxparity;
         Rxparity <= Rxstop;
         Paritygen <= Paritygen XOR Rxstop;-- Form Parity As Data Shifts By
         Rxstop <= Rx;
     END IF ;
        END IF;
    END PROCESS;
Async:  -- Rxidle Requires Async Preset Since It Is Clocked By Rxclk And
        -- Its Value Determines Whether Rxclk Gets Generated
    PROCESS ( Reset, Rxclk )
    BEGIN
        IF Reset = ''1'' THEN
           Rxidle <= ''0'';
        ELSIF Rxclk''EVENT And Rxclk = ''1'' THEN
           Rxidle <= NOT Rxidle AND NOT Rxreg(0);
        END IF;
    END PROCESS Async;
Txio: -- Load Txhold And Set Txdatardy On Falling Edge Of Write
-- Clear Txdatardy On Falling Edge Of Txdone
    PROCESS (Reset, Clkx16)
VARIABLE Wr1,Wr2: Std_logic; -- Write Signal Delayed 1 And 2 Cycles
VARIABLE Txdone1: Std_logic;        -- Txdone Signal Delayed One Cycle
    BEGIN
IF Reset=''1'' THEN
     Txdatardy <= ''0'' ;
     Wr1 := ''0'' ;
     Wr2 := ''0'' ;
     Txdone1 := ''0'' ;
ELSIF Clkx16''Event AND Clkx16 = ''1'' THEN
     IF Wr1 = ''0'' AND Wr2= ''1'' THEN
         -- Falling Edge On Write Signal. New Data In Txhold Latches
         Txdatardy  <= ''1'';
     ELSIF Txdone = ''0'' AND Txdone1 = ''1'' THEN
         -- Falling Edge On Txdone Signal. Txhold Has Been Read.
         Txdatardy  <= ''0'';
     END IF;
