cordic算法verilog实现(复杂版)转载
  • module cordic (clk,rst_n,ena,phase_in,sin_out,cos_out,eps);
  • parameter DATA_WIDTH=8;
  • parameter PIPELINE=8;
  • input     clk;
  • input     rst_n;
  • input     ena;
  • input  [DATA_WIDTH-1:0]         phase_in;
  • output [DATA_WIDTH-1:0]  sin_out;
  • output [DATA_WIDTH-1:0]  cos_out;
  • output [DATA_WIDTH-1:0]  eps;
  • reg    [DATA_WIDTH-1:0]  sin_out;
  • reg    [DATA_WIDTH-1:0]  cos_out;
  • reg    [DATA_WIDTH-1:0]  eps;
  • reg    [DATA_WIDTH-1:0]  phase_in_reg;
  • reg        [DATA_WIDTH-1:0]     x0,y0,z0;
  • reg        [DATA_WIDTH-1:0]  x1,y1,z1;
  • reg        [DATA_WIDTH-1:0]  x2,y2,z2;
  • reg        [DATA_WIDTH-1:0]  x3,y3,z3;
  • reg        [DATA_WIDTH-1:0]  x4,y4,z4;
  • reg        [DATA_WIDTH-1:0]  x5,y5,z5;
  • reg        [DATA_WIDTH-1:0]  x6,y6,z6;
  • reg        [DATA_WIDTH-1:0]  x7,y7,z7;
  • reg        [1:0]   quadrant[PIPELINE:0];
  • integer i;
  • //get real quadrant and map to first_n quadrant
  • always@(posedge clk or negedge rst_n)
  • begin
  •         if(!rst_n)
  •                phase_in_reg<=8'b0000_0000;
  •         else
  •                if(ena)
  •                        begin
  •                                case(phase_in[7:6])
  •                                       2'b00:phase_in_reg<=phase_in;
  •                                       2'b01:phase_in_reg<=phase_in-8'h40;  //-pi/2
  •                                       2'b10:phase_in_reg<=phase_in-8'h80;  //-pi
  •                                       2'b11:phase_in_reg<=phase_in-8'hc0;  //-3pi/2
  •                                       default:;
  •                                 endcase
  •                         end
  • end
  • begin
  •         if(!rst_n)
  •                begin
  •                        x0<=8'b0000_0000;
  •                        y0<=8'b0000_0000;
  •                        z0<=8'b0000_0000;
  •                end
  •          else
  •                if(ena)
  •                        begin
  •                                x0<=8'h4D;  //define aggregate constant Xi=1/P=1/1.6467=0.60725 (Xi=2^7*P+8'h4D)
  •                                y0<=8'h00;
  •                                z0<=phase_in_reg;
  •                        end
  • end
  • //level 1
  • begin
  •         if(!rst_n)
  •                begin
  •                        x1<=8'b0000_0000;
  •                        y1<=8'b0000_0000;
  •                        z1<=8'b0000_0000;
  •                end
  •          else
  •                 if(ena)
  •                        if(z0[7]==1'b0)
  •                                begin
  •                                       x1<=x0-y0;
  •                                       y1<=y0+x0;
  •                                       z1<=z0-8'h20;  //45deg
  •                                end
  •                else
  •                        begin
  •                                       x1<=x0+y0;
  •                                       y1<=y0-x0;
  •                                       z1<=z0+8'h20;  //45deg
  •                end
  • end
  • //level 2
  • begin
  •         if(!rst_n)
  •                begin
  •                        x2<=8'b0000_0000;
  •                        y2<=8'b0000_0000;
  •                        z2<=8'b0000_0000;
  •                end
  •          else
  •                 if(ena)
  •                        if(z1[7]==1'b0)
  •                                begin
  •                                       x2<=x1-{y1[DATA_WIDTH-1],y1[DATA_WIDTH-1:1]};
  •                                       y2<=y1+{x1[DATA_WIDTH-1],x1[DATA_WIDTH-1:1]};
  •                                       z2<=z1-8'h12;  //26deg
  •                                end
  •                         else
  •                                begin
  •                                       x2<=x1+{y1[DATA_WIDTH-1],y1[DATA_WIDTH-1:1]};
  •                                       y2<=y1-{x1[DATA_WIDTH-1],x1[DATA_WIDTH-1:1]};
  •                                       z2<=z1+8'h12;
  •                                end
  • end
  • //level 3
  • begin
  •         if(!rst_n)
  •                begin
  •                        x3<=8'b0000_0000;
  •                        y3<=8'b0000_0000;
  •                        z3<=8'b0000_0000;
  •                 end
  •          else
  •                 if(ena)
  •                        if(z2[7]==1'b0)
  •                                begin
  •                                       x3<=x2-{{2{y2[DATA_WIDTH-1]}},y2[DATA_WIDTH-1:2]};
  •                                       y3<=y2+{{2{x2[DATA_WIDTH-1]}},x2[DATA_WIDTH-1:2]};
  •                                       z3<=z2-8'h09;  //14deg
  •                                end
  •                         else
  •                                begin
  •                                       x3<=x2+{{2{y2[DATA_WIDTH-1]}},y2[DATA_WIDTH-1:2]};
  •                                       y3<=y2-{{2{x2[DATA_WIDTH-1]}},x2[DATA_WIDTH-1:2]};
  •                                       z3<=z2+8'h09;
  •                                end
  • end
  • //level 4
  • begin
  •         if(!rst_n)
  •                begin
  •                        x4<=8'b0000_0000;
  •                        y4<=8'b0000_0000;
  •                        z4<=8'b0000_0000;
  •                end
  •          else
  •                 if(ena)
  •                        if(z3[7]==1'b0)
  •                                begin
  •                                       x4<=x3-{{3{y3[DATA_WIDTH-1]}},y3[DATA_WIDTH-1:3]};
  •                                       y4<=y3+{{3{x3[DATA_WIDTH-1]}},x3[DATA_WIDTH-1:3]};
  •                                       z4<=z3-8'h04;  //7deg
  •                                end
  •                         else
  •                                begin
  •                                       x4<=x3+{{3{y3[DATA_WIDTH-1]}},y3[DATA_WIDTH-1:3]};
  •                                       y4<=y3-{{3{x3[DATA_WIDTH-1]}},x3[DATA_WIDTH-1:3]};
  •                                       z4<=z3+8'h04;
  •                                end
  • end
  • //level 5
  • begin
  •         if(!rst_n)
  •                begin
  •                        x5<=8'b0000_0000;
  •                        y5<=8'b0000_0000;
  •                        z5<=8'b0000_0000;
  •                end
  •          else
  •                 if(ena)
  •                        if(z4[7]==1'b0)
  •                                begin
  •                                       x5<=x4-{{4{y4[DATA_WIDTH-1]}},y4[DATA_WIDTH-1:4]};
  •                                       y5<=y4+{{4{x4[DATA_WIDTH-1]}},x4[DATA_WIDTH-1:4]};
  •                                       z5<=z4-8'h02;  //4deg
  •                                end
  •                         else
  •                                begin
  •                                       x5<=x4+{{4{y4[DATA_WIDTH-1]}},y4[DATA_WIDTH-1:4]};
  •                                       y5<=y4-{{4{x4[DATA_WIDTH-1]}},x4[DATA_WIDTH-1:4]};
  •                                       z5<=z4+8'h02;
  •                                end
  • end
  • //level 6
  • begin
  •         if(!rst_n)
  •                begin
  •                        x6<=8'b0000_0000;
  •                        y6<=8'b0000_0000;
  •                        z6<=8'b0000_0000;
  •                end
  •          else
  •                 if(ena)
  •                        if(z5[7]==1'b0)
  •                                begin
  •                                       x6<=x5-{{5{y5[DATA_WIDTH-1]}},y5[DATA_WIDTH-1:5]};
  •                                       y6<=y5+{{5{x5[DATA_WIDTH-1]}},x5[DATA_WIDTH-1:5]};
  •         z6<=z5-8'h01;  //2deg
  •                                end
  •                         else
  •                               begin
  •                                       x6<=x5+{{5{y5[DATA_WIDTH-1]}},y5[DATA_WIDTH-1:5]};
  •                                       y6<=y5-{{5{x5[DATA_WIDTH-1]}},x5[DATA_WIDTH-1:5]};
  •                                       z6<=z5+8'h01;
  •                                end
  • end
  • begin
  •         if(!rst_n)
  •             for(i=0;i<=PIPELINE;i=i+1)
  •                        quadrant<=2'b00;
  •         else
  •                if(ena)
  •                        begin
  •                          for(i=0;i<IPELINE;i=i+1)
  •                             quadrant[i+1]<= quadrant;
  •                             quadrant[0]<=phase_in[7:6];
  •                         end
  • end
  • begin
  •      if(!rst_n)
  •          begin
  •            sin_out<=8'b0000_0000;
  •            cos_out<=8'b0000_0000;
  • eps<=8'b0000_0000;
  •          end
  •      else
  •         if(ena)
  •            case(quadrant[7])
  •              2'b00:begin
  •                 sin_out<=y6;
  •                 cos_out<=x6;
  •                 eps<=z6;
  •              end
  •               2'b01:begin
  •                  sin_out<=x6;
  •                  cos_out<=~(y6)+ 1'b1;
  •                  eps<=z6;
  •              end
  •             2'b10:begin
  •                  sin_out<=~(y6)+ 1'b1;
  •                  cos_out<=~(x6)+ 1'b1;
  •                  eps<=z6;
  •             end
  •             2'b11:begin
  •                  sin_out<=~(x6)+ 1'b1;
  •                  cos_out<=y6;
  •                  eps<=z6;
  •             end
  •          encase
  • end
  • endmodule
