c# 操作FTP文件类(2)
c# 操作FTP文件类(2)
#region 在ftp上创建目录
        public void MakeMultipleDir(string dirName)
            if (dirName != "")
                string[] dirs = dirName.Trim('/').TrimEnd('/').Split('/');
                if (dirs.Length > 0)
                    string oldpath = "";   //文件夹完整路径
                    string nowdir = "";    //当前文件夹名称
                    bool b = true;         //是否存在该文件夹
                    for (int i = 0; i < dirs.Length; i++)
                        b = true;
                        string[] list = GetFileList(oldpath.TrimEnd('/'));
                        if (list != null)
                            for (int z = 0; z < list.Length; z++)
                                if (i > 0)
                                    nowdir = dirs[i - 1] + "/" + dirs[i];
                                else
                                    nowdir = dirs[i];
                                if (list[z] == nowdir)
                                    b = false;
                                    break;
                        oldpath += dirs[i] + "/";
                        if (b)
                            MakeDir(oldpath.TrimEnd('/'));
                else
                    MakeDir(dirName);
        /// <summary>
        /// 在ftp上创建目录
        /// </summary>
        /// <param name="dirName"></param>
        public void MakeDir(string dirName)
            try
                string uri = "ftp://" + _serverIP + "/" + dirName;
                Connect(uri);//连接
                reqFTP.Method = WebRequestMethods.Ftp.MakeDirectory;
                FtpWebResponse response = (FtpWebResponse)reqFTP.GetResponse();
                response.Close();
            catch (Exception ex)
                // MessageBox.Show(ex.Message);
        #endregion
        #region 删除ftp上目录
        /// <summary>
        /// 删除ftp上目录
        /// </summary>
        public void DelDir(string dirName)
            try
                Connect(uri);//连接
                reqFTP.Method = WebRequestMethods.Ftp.RemoveDirectory;
                response.Close();
        #endregion
        #region 获得ftp上文件大小
        /// <summary>
        /// 获得ftp上文件大小
        /// </summary>
        /// <param name="filename"></param>
        /// <returns></returns>
        public long GetFileSize(string filename)
            long fileSize = 0;
            filename = filename.Replace("\\", "/");
            try
                string uri = "ftp://" + filename;
                this.Connect(uri);//连接
                reqFTP.Method = WebRequestMethods.Ftp.GetFileSize;
                fileSize = response.ContentLength;
                response.Close();
            return fileSize;
        #endregion
        #region 重命名对象
        /// <summary>
        /// 重命名对象
        /// </summary>
        /// <param name="filePath"></param>
        /// <param name="newFilename"></param>
        public void Rename(string filePath, string newFilename)
            try
                string uri = "ftp://" + _serverIP + "/" + filePath;
                Connect(uri);//连接
                reqFTP.Method = WebRequestMethods.Ftp.Rename;
                reqFTP.RenameTo = newFilename;
                response.Close();
        #endregion
        #region 获得文件明细
        /// <summary>
        /// 获得文件明细
        /// </summary>
        public string[] GetFilesDetailList()
            return GetFileList("ftp://" + _serverIP + "/", WebRequestMethods.Ftp.ListDirectoryDetails);
        /// <summary>
        /// 获得文件明细
        /// </summary>
        /// <param name="path"></param>
        public string[] GetFilesDetailList(string path)
            path = path.Replace("\\", "/");
            return GetFileList("ftp://" + _serverIP + "/" + path, WebRequestMethods.Ftp.ListDirectoryDetails);
        #endregion
