斐波那契堆(一)之图文解析和C语言的实现(3)
其中fib_heap_consolidate(heap)的作用是合并斐波那契堆的根链表中相同度数的树,它的相关代码如下:
view sourceprint?
01.1 /*
02.2  * 将node链接到root根结点
03.3  */
04.4 static void fib_heap_link(FibHeap * heap, FibNode * node, FibNode *root)
05.5 {
06.6     // 将node从双链表中移除
07.7     fib_node_remove(node);
08.8     // 将node设为root的孩子
09.9     if (root->child == NULL)
10.10         root->child = node;
11.11     else
12.12         fib_node_add(node, root->child);
13.13
14.14     node->parent = root;
15.15     root->degree++;
16.16     node->marked = 0;
17.17 }
18.18
19.19 /*
20.20  * 创建fib_heap_consolidate所需空间
21.21  */
22.22 static void fib_heap_cons_make(FibHeap * heap)
23.23 {
24.24     int old = heap->maxDegree;
25.25
26.26     // 计算log2(x),'+1'意味着向上取整!
27.27     // ex. log2(13) = 3,向上取整为3+1=4。
28.28     heap->maxDegree = LOG2(heap->keyNum) + 1;
29.29
30.30     // 如果原本空间不够,则再次分配内存
31.31     if (old >= heap->maxDegree)
32.32         return ;
33.33
34.34     // 因为度为heap->maxDegree可能被合并,所以要maxDegree+1
35.35     heap->cons = (FibNode **)realloc(heap->cons,
36.36             sizeof(FibHeap *) * (heap->maxDegree + 1));
37.37 }
38.38
39.39 /*
40.40  * 合并斐波那契堆的根链表中左右相同度数的树
41.41  */
42.42 static void fib_heap_consolidate(FibHeap *heap)
43.43 {
44.44     int i, d, D;
45.45     FibNode *x, *y, *tmp;
46.46
47.47     fib_heap_cons_make(heap);//开辟哈希所用空间
48.48     D = heap->maxDegree + 1;
49.49
50.50     for (i = 0; i < D; i++)
51.51         heap->cons = NULL;
52.52
53.53     // 合并相同度的根节点,使每个度数的树唯一
54.54     while (heap->min != NULL)
55.55     {
56.56         x = fib_heap_remove_min(heap);    // 取出堆中的最小树(最小节点所在的树)
57.57         d = x->degree;                    // 获取最小树的度数
58.58         // heap->cons[d] != NULL,意味着有两棵树(x和y)的'度数'相同。
59.59         while (heap->cons[d] != NULL)
60.60         {
61.61             y = heap->cons[d];            // y是'与x的度数相同的树'
62.62             if (x->key > y->key)        // 保证x的键值比y小
63.63             {
64.64                 tmp = x;
65.65                 x = y;
66.66                 y = tmp;
67.67
68.68             }
69.69             fib_heap_link(heap, y, x);    // 将y链接到x中
70.70             heap->cons[d] = NULL;
71.71             d++;
72.72         }
73.73         heap->cons[d] = x;
74.74     }
75.75     heap->min = NULL;
76.76
77.77     // 将heap->cons中的结点重新加到根表中
78.78     for (i=0; i<D; i++)
79.79     {
80.80         if (heap->cons != NULL)
81.81         {
82.82             if (heap->min == NULL)
83.83                 heap->min = heap->cons;
84.84             else
85.85             {
86.86                 fib_node_add(heap->cons, heap->min);
87.87                 if ((heap->cons)->key < heap->min->key)
88.88                     heap->min = heap->cons;
89.89             }
90.90         }
91.91     }
92.92 }
5. 减小节点值
减少斐波那契堆中的节点的键值,这个操作的难点是:如果减少节点后破坏了'最小堆'性质,如何去维护呢?下面对一般性情况进行分析。
(1) 首先,将'被减小节点'从'它所在的最小堆'剥离出来;然后将'该节点'关联到'根链表'中。 倘若被减小的节点不是单独一个节点,而是包含子树的树根。则是将以'被减小节点'为根的子树从'最小堆'中剥离出来,然后将该树关联到根链表中。
(2) 接着,对'被减少节点'的原父节点进行'级联剪切'。所谓'级联剪切',就是在被减小节点破坏了最小堆性质,并被切下来之后;再从'它的父节点'进行递归级联剪切操作。
      而级联操作的具体动作则是:若父节点(被减小节点的父节点)的marked标记为false,则将其设为true,然后退出。
                                                          否则,将父节点从最小堆中切下来(方式和'切被减小节点的方式'一样);然后递归对祖父节点进行'级联剪切'。
      marked标记的作用就是用来标记'该节点的子节点是否有被删除过',它的作用是来实现级联剪切。而级联剪切的真正目的是为了防止'最小堆'由二叉树演化成链表。
(3) 最后,别忘了对根链表的最小节点进行更新。
继承事业,薪火相传
很好的代码的分享,感谢 分享
