c#操作excel方式一:stream简单读写excel
需要命名空间
using System.IO;
界面:
记得添加openFileDialog
注意名字,改成跟代码里的对应
写文件按钮代码:
      private void button2_Click(object sender, EventArgs e)
                int i = 0;
                StreamWriter aFile = null;
                aFile = File.CreateText("aFile .csv");
             //aFile.WriteLine(i.ToString() + "," + (i + 1).ToString() + "," + (i + 2));
              aFile.WriteLine("\"" + i.ToString() + "," + (i + 1).ToString() + "," + (i + 2)+"\"");
             //aFile.WriteLine("\""+i.ToString() + "," + (i + 1).ToString() +"\""+ "," + (i + 2));
                aFile.Close();
                    aFile.Dispose();
                    MessageBox.Show("end!");
注意逗号分隔符的用法,逗号分隔符把内容分成几个单元格.
如果要在同一个单元格中写入逗号,则要在该单元格内容前后加上双引号加上,3种情况产生的格式如下:
读文件按钮按钮:
      private void button1_Click(object sender, EventArgs e)
                if (openFileDialog.ShowDialog() == DialogResult.OK)
                    string str = null;
                    FileStream fs = new FileStream(openFileDialog.FileName, FileMode.Open, FileAccess.Read, FileShare.ReadWrite);
                    StreamReader reader = new StreamReader(fs, System.Text.Encoding.UTF8);
                    while ((str = reader.ReadLine()) != null)
                        // split the string
                        //MessageBox.Show(str);
                        string[] strs = str.Split(',');
                        string show_str = "";
                        for(int i=0;i<strs.Length;i++)
                            if (i == strs.Length-1)
                                show_str += strs.ToString();
                            else
                                show_str += strs.ToString() + ",";
                        this.label1.Text = show_str;
                    reader.Close();
上面三种写入方式读出的字符串对应如下:
对应读出的字符串:
str=0,1,2
即strs[0]=0
strs[1]=1
strs[2]=2
对应的字符串:
str="0,1,2",
即strs[0]="0
strs[1]=1
strs[2]=2"
对应的字符串:
str="0,1",2,
即strs[0]="0
strs[1]=1"
strs[2]=2
