一、数据采集重建故障的解决思路:
从下面的数据采集和重建流程图来看,数据采集和重建主要由机架部分和控制台部分组成。可以利用调入原来存好的正常原始数据(Detector fan,Source fan)重建图像,就可以区分故障的大概位置。例如,若重建的图像正常,则故障应在机架一侧;若图像出错,则问题出在控制台一侧。
![](http://upload.semidata.info/new.eefocus.com/article/image/2014/02/12/52fb3dfbb5c8d-thumb.jpg)
1.机架部分的故障诊断:
主要由data诊断程序和feud诊断程序来判断故障。data诊断程序主要判断探测器、VFSC的故障;
而feud诊断程序主要判断VFSC的线性和DPPC、和时序电路的故障:
A.data诊断程序的使用:
IQ〉site_cnf
显示为
The site configuration screen will be displayed:
Site Configuration Parameters-Main Menu
Changes available for diagnostic purposes only (reset on reboot)。
Calibrate Flats (0 = Disable , 1 = Enable) 0
Calibrate Pilot (0 = Disable , 1 = Enable) 0
Ripple Correction (0 = Disable ,1 = Enable) 1
Beam limiter Half Field (0 = off , 1 = on) 1
Stare of Field (-1 = Variable , SOF detector number ) -1
Delta Data (0 = Disable ,1 = Enable) 1
Look for Bad Dets ,Det Avg (0 = normal,1 = off) 0
Recon storage options CT : IMG回车
Pilot: IMG
Changes maintained after system is rebooted.
BP Expansion Board(s) (-Slot # = Disable) 11 12
AP Board(s) (-Slot # = Disable) 5 6 7 9
Study Number # # #
Quit (after saving new Configuration table)回车
Quit (Without saving new Configuration table)
Use up and down arrows to select parameter to change.
Recon stage (CT) (1 = store, 0 = no storage )
source fan 0 1
detector fan 0 1
AP stages (CHOOSE 1 STORAGE STAGE FOR AP OPERATIONS):
compressed air cal 0
spectrum corrected 0
convolved 0
Recon stage (PILOT) (1 = store ,0 = no storage)
source fan 0
更改以上参数后,扫描水模,可以获得原始数据图像。在图像状态下,打入_dita进入诊断程序。正常的显示数据入图,若有明显的亮线或暗线则有故障。
B.feud诊断程序的使用:
在IQ〉feud进入诊断程序显示如下:
0.)ALL TEST
1.)COUNTROL REGISTER R/W 2.) TRANSFER COUNTER
3.)DATA GRAMBBER 4.)LINEAR TRANSFER
5.)LOG CHECK WALKING BIT 6.)LOG CHECK
7.)BACKGROUND CHECK 8.)DELTA DATA LINEAR TRANSFER
9.)DELTA DATA LOG CHECK A.)GATE ARRAY COUNTER WORD
WALKING BIT
B.)GATE ARRAY COUNTER WORD C.)GATE ARRAY TIME COUNTER
D.)DATA GAPS E.) DATA TRANSFER COUNTER
F.)MAINTENANCE MODE SCAN G.)IP TIMER
H.)PREDATA WORD 3 I.)PACKING
J.)DELTA DATA 1ST TRANSFER DISABLE K.)DECTOR AVERAGING
L.)VOLTAGE TO FREQUENCY LINEARITY M.)QUIT
如果选择0,将进行所有可选项的诊断程序,如果出错根据出错的程序位置判断产生错误的板子。其中,L选项可以测出VFSC或探测器线性故障,在实际维修中非常有用。
C.维修实例:
a.扫描病人有斜道伪影,扫描水模也有斜道伪影,扫描水模获得原始数据,用dita
诊断程序发现有一个探测器的数据全白,删掉此探测器或者更换一个探测器模块,扫描水模,图像正常。
b.扫描病人发现有大量黑白相间的斜道伪影,扫描水模也有大量黑白相间的斜道伪影,扫描水模获得原始数据,用dita诊断程序发现有400个探测器的数据全白。查看相应探测器母板,发现+15v电源的保险丝烧断。更换新的保险丝依然烧断,测量每一个探测器模块上的C1和C2的阻值,发现一个探测器模块上的C1两端阻值的为零。更换此探测器和保险管,保险管不再烧毁,扫描水模图像正常。
c.扫描病人有井字型伪影,扫描水模也有井字型伪影,扫描水模获得原始数据,用dita
诊断程序发现有四个探测器的数据全白,互相之间相差1200个探测器。删掉对应四个探测器或者更换对应的VFSC,扫描水模,图像正常。
d.扫描病人偶尔有淡淡的斜道伪影,扫描水模也偶尔有淡淡的斜道伪影,扫描水模获得原始数据,用dita诊断程序没有发现异常的探测器。用feud的程序的L选项诊断探测器和通道的线性,发现有一个探测器的线性不好,删掉此探测器或者更换一个探测器模块,扫描水模,图像正常。
e.扫描病人偶尔有黑色的斜道伪影,扫描水模图像正常。扫描水模获得原始数据,用dita诊断程序发现有的探测器上有黑点,而且位置随机,将探测器母板在Cardfile
一侧的所有缆线插头拔下后用清洗剂清洗,将Cardfile上的所有板子拔下后清洗,恢复后扫描图像正常。
f.扫描头颅正常,扫描胸、腹图像发黑,CT值相差几百。扫描半野水模图像正常,扫描全野水模图像发黑,CT值相差几百。扫描半野定位片正常,扫描全野定位片中间图像正常,两边发黑。可以判断为X线全野和半野转换部分出现问题,将球管取下,发现球管上的半野全野转换器卡死,更换新的半野全野转换器,扫描病人,图像正常。
g.扫描病人出现环形伪影。在第四代CT机上出现环形伪影一般为旋转机架上X线光路出现问题。观察X线光路所经过的部分没有发现异物。将遮线器打到10mm观察射线形成器,发现里面的塑料补偿器被X线烤裂。更换塑料补偿器,扫描病人,图像正常。
2.控制台部分的故障诊断:控制台部分的重建部分主要包括SIF(一块)、MPM(一到两块)、BP(一块)、EP(两块)、XAP(四块)、DISPLAY(一块)。每块板子都有自己的诊断程序,但是诊断程序运行速度非常慢,为了快速准确地排除重建的故障,针对有两块以上的板子,可以利用软件删除或硬件删除(直接拔出)的办法,取消该板子的功能后重建图像,来判断故障所在。
软件取消:IQ〉site_cnf
显示为
Pilot: IMG
BP Expansion Board(s) (-Slot # = Disable) -11 -12
AP Board(s) (-Slot # = Disable) 5 -6 -7 -9
Study Number # # #
更改以上参数后,就可以将6、7、9槽的三块XAP板,11、12槽的两块EB板取消功能。
维修实例:
a.扫描头颅、胸、腹图像发黑,CT值相差几百。扫描半野、全野水模图像发黑,CT值相差几百。将其中的一块EP板取消后,重建图像恢复正常。
b.开机时机器调入重建程序时提示一块EP板出错,扫描病人不重建。将该EP板软件取消后,重新开机,故障依旧。将该EP板拔出后,重新开机,工作正常。 |
