脚本是Python写的,树莓派上可直接运行。
#!/usr/bin/env python#-*- coding:utf-8 -*-import httplib, urllibimport socketimport timeparams = dict( login_email="email", # replace with your email login_password="password", # replace with your password format="json", domain_id=100, # replace with your domain_od, can get it by API Domain.List record_id=100, # replace with your record_id, can get it by API Record.List sub_domain="www", # replace with your sub_domain record_line="默认",)current_ip = Nonedef ddns(ip): params.update(dict(value=ip)) headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/json"} conn = httplib.HTTPSConnection("dnsapi.cn") conn.request("POST", "/Record.Ddns", urllib.urlencode(params), headers) response = conn.getresponse() print response.status, response.reason data = response.read() print data conn.close() return response.status == 200def getip(): sock = socket.create_connection(('ns1.dnspod.net', 6666)) ip = sock.recv(16) sock.close() return ipif __name__ == '__main__': while True: try: ip = getip() print ip if current_ip != ip: if ddns(ip): current_ip = ip except Exception, e: print e pass time.sleep(30)
替换上你的Email,密码,域名ID,记录ID等参数,就可以运行了。 会在后台一直运行,每隔30秒检查一遍IP,如果修改了就更新IP。
获得domain_id可以用
curl curl -k https://dnsapi.cn/Domain.List -d "login_email=xxx&login_password=xxx"获得record_id类似
curl -k https://dnsapi.cn/Record.List -d "login_email=xxx&login_password=xxx&domain_id=xxx"加入开机自动运行的方法:
编辑/etc/rc.local文件,在“exit 0”那一行前面加上一行
su root -c "python /home/pypod.py" |
