基于FPGA的图像处理(五)--状态机
基于FPGA的图像处理(五)--状态机
使用FPGA实现各种算法时,状态机是很常用的方法,在SysGen中有两种非常简便的方法构建状态机,一是使用Mcode,以switch-case语句轻松实现,二是使用SysGen自带状态机模块。状态机假设我们要从01序列中检测出1011序列,则状态机模型如下Next State Matrix:[0 1; 2 1; 0 3; 2 1]Output Matrix : [0 0; 0 0; 0 0; 0 1][[wysiwyg_imageupload:756:]]                     一、使用Mcode实现上一篇博客讲解了在Sysgen中Mcode的限制能力,这里直接使用构建模型如下:[[wysiwyg_imageupload:751:]]               Singal From Workspace用于产生一个01序列,作为输入信号。gatwayIn将数据类型转化为UFix_1_0添加Mcode函数stateMcode.m<span style="font-size:24px;">function [nextState, matched] = stateMcode(currentState, din)% This is the update function for detecting a pattern of 1011% This function represents a stateless and combination logic block.% The output nextState should be to a register, and the output% of the register should be fed back to the input currentState.% Because the state register block has a feed back connection, in% order to propagate the port prototypes automatically, the prototype% of nextState should be determined only by constants or through% an explicity xfix() call.   seen_none = 0; % initial state, if input is 1, switch to seen_1  seen_1 = 1;    % first 1 has been seen, if input is 0, switch                 % seen_10  seen_10 = 2;   % 10 has been detected, if input is 1, switch to                 % seen_1011  seen_101 = 3;  % now 101 is detected, is input is 1, 1011 is                 % detected and the FSM switches to seen_1   % the default value of matched is false  matched = false;   switch currentState   case seen_none    if din==1      nextState = seen_1;    else      nextState = seen_10;    end   case seen_1 % seen first 1    if din==1      nextState = seen_1;    else      nextState = seen_10;    end   case seen_10 % seen 10    if din==1      nextState = seen_101;    else      % no part of sequence seen, go to seen_none      nextState = seen_none;    end   case seen_101    if din==1      nextState = seen_1;      matched = true;    else      nextState = seen_10;      matched = false;    end   otherwise    % if nextState is not assigned outside the switch statement,    % an otherwise statment is required    nextState = seen_none;  end </span> Scope效果如图:[[wysiwyg_imageupload:752:]]                                         二、使用Mealy State Machine模块实现构建模型:[[wysiwyg_imageupload:753:]]               设置Mealy State Machine参数,就是状态机的参数[[wysiwyg_imageupload:754:]]                           仿真结果如下:[[wysiwyg_imageupload:755:]]                                         在进行FPGA图像处理时,经常会用到状态机,这几天刚学习过,记录一下,其实使用Verilog直接实现也不是很难,只是会比SysGen稍微麻烦一些,修改起来也会花费更多的时间。 Model Based Design 在Xilinx 的工具中逐渐得到加强,相信以后会更加的方便。 来源:机器视觉的博客
