OSTCBX/Y OSTCBBitX/Y 在TCB结构里的作用
关于任务就绪的就绪组和就绪表操作
例如PRIO=11 11为00001011
设置完成后应为:
OSRdyGrp=10000010
OSRdyTbl[1]=00001000
过程
ptcb->OSTCBY = (INT8U)(prio>> 3)=1;这个是就绪组中的位序号
ptcb->OSTCBX = (INT8U)(prio &0x07)=011;这个是在就绪表OSRdyTbl[ptcb->OSTCBY]中的位序号
但是按位序号不好设定就绪表和就绪组,要转成
ptcb->OSTCBBitY = (INT8U)(1<< ptcb->OSTCBY);00000010
ptcb->OSTCBBitX = (INT8U)(1<< ptcb->OSTCBX);00001000
以后直接把ptcb->OSTCBBitY 与就绪组按位或
ptcb->OSTCBBitX与OSRdyTbl[ptcb->OSTCBY]按位或
这样就将优先级11的任务就绪了
例子:
void OS_EventTaskWait (OS_EVENT *pevent)
INT8U y;
OSTCBCur->OSTCBEventPtr = pevent;
/*功能:取消当前任务的就绪状态*/
y = OSTCBCur->OSTCBY; //获取当前任务的组号
OSRdyTbl[y] &= ~OSTCBCur->OSTCBBitX;//取得对应组号的就绪表,并把指定任务清空
if (OSRdyTbl[y] == 0) { //如果当前就绪表全为0,则把就绪组的对应为清0
OSRdyGrp &= ~OSTCBCur->OSTCBBitY;
/*把当前任务的优先级存入当前事件的等待任务列表里*/
pevent->OSEventTbl[OSTCBCur->OSTCBY] |= OSTCBCur->OSTCBBitX; /* Put task in waiting list */
pevent->OSEventGrp |= OSTCBCur->OSTCBBitY;
