OK6410的第一个驱动程序--点灯
OK6410的第一个驱动程序--点灯
开始自己的嵌入式之旅了。一切神秘的面纱均可以由闪亮的LED揭开。
贴上自己的驱动程序:
#include<linux/kernel.h>
#include<linux/module.h>
#include<linux/init.h>
#include<linux/fs.h>
#include<linux/pci.h>
#include<linux/ioctl.h>
#include<linux/types.h>
#include<linux/cdev.h>
#include<linux/device.h>
#include<linux/gpio.h>
#include<mach/hardware.h>
#include<mach/regs-gpio.h>
#include<mach/gpio-bank-m.h>
#include<plat/gpio-cfg.h>
#include <mach/map.h>
#define DEVICE_NAME "s3c6410leds"
#define LED_ON 1
#define LED_OFF 0
dev_t devid;
static int leds_open(struct inode *inode , struct file *file)
  unsigned tmp;
  for(tmp=0;tmp<4;tmp++)
  s3c_gpio_cfgpin(S3C64XX_GPM(tmp),S3C_GPIO_SFN(1));
  return 0;
static long leds_ioctl( struct file *filp,unsigned int cmd,
                        unsigned long arg)
  if(arg>4) return -EINVAL;
  //tmp = __raw_readl(S3C64XX_GPMDAT);
  switch(cmd)
    case LED_ON:  //tmp &= ~(1<<arg); writel(tmp,S3C64XX_GPMDAT);
                  gpio_set_value(S3C64XX_GPM(arg),0);
                  return 0;
    case LED_OFF: //tmp |= 1<<arg; writel(tmp,S3C64XX_GPMDAT);
                  gpio_set_value(S3C64XX_GPM(arg),1);
                  return 0;
    default: return -EINVAL;
static struct file_operations leds_ops = {
    .owner = THIS_MODULE,
    .open = leds_open,
    .unlocked_ioctl = leds_ioctl,
static struct cdev *cdev_led;
static struct class *led_class;
static int __init s3c6410_leds_init(void)
  int val;
  unsigned tmp;
  tmp = readl(S3C64XX_GPMPUD); //pull up gpiom0~3
  tmp &= ~(0xffff);
  tmp |= 0xaa;
  writel(tmp,S3C64XX_GPMPUD);
//  devid = MKDEV(LED_MAJOR,0);
//  val = register_chrdev_region(devid,1,DEVICE_NAME);
  val = alloc_chrdev_region(&devid,0,1,DEVICE_NAME);
  if(val) return -1;
  cdev_led = cdev_alloc();
  cdev_init(cdev_led,&leds_ops);
  val = cdev_add(cdev_led,devid,1);
  if(val)
//   printk(KERN_INFO "Add device led error!\n");
    return -1;
  led_class = class_create(THIS_MODULE,DEVICE_NAME);
  device_create(led_class,NULL,devid,NULL,"%s",DEVICE_NAME);
// printk(KERN_INFO "LED Initilized I'm in! ^_^ \n");
  return 0;
static void __exit s3c6410_leds_exit(void)
  cdev_del(cdev_led);
  device_destroy(led_class,devid);
  class_destroy(led_class);
  unregister_chrdev_region(devid, 1);
module_init(s3c6410_leds_init);
module_exit(s3c6410_leds_exit);
MODULE_AUTHOR("embedded lover");
MODULE_DESCRIPTION("s3c6410 led test");
MODULE_LICENSE("GPL");
在linux2.6版本之后我们是可以让驱动程序自动建立设备节点文件的,注意下这点。
下面是自己的测试程序:
#include<stdio.h>
#include<stdlib.h>
#include<unistd.h>
#include<sys/ioctl.h>
#define LED_ON 1
#define LED_OFF 0
int main(int argc, char **argv)
  int fd = -1;
  unsigned int led_no;
  fd = open("/dev/s3c6410leds",0);
  if(fd<0)
    printf("Can not open device leds\n");
    return -1;
  led_no = strtoul(argv[1],0,0) - 1;
  if(!strcmp(argv[2],"on"))
    ioctl(fd,LED_ON,led_no);
  else if(!strcmp(argv[2],"off"))
    ioctl(fd,LED_OFF,led_no);
  else goto err;
  close(fd);
  return 0;
err:
  if(fd>0) close(fd);
  return -1;
在写完驱动程序后有两个方法可以编译成可加载的.ko模块文件,一个是将驱动放到内核原码的driver/char目录下,再在Makefile下新增一个obj-m += name.o。再在顶层文件夹下执行make modules ,然后就可以在driver/char下找到对应的.ko文件。另外一个方法就是自己写makefile了,这样也方便。
Makefile如下:
all: default
obj-m += create_chrdev.o
default:
    make -C /home/xu/Myworks/kernel/linux-2.6.22 M=`pwd` modules
clean:
    make -C /home/xu/Myworks/kernel/linux-2.6.22 M=`pwd` clean
最后将模块文件加载到目标板上:insmod,移除模块用:rmmod。
