电子学─放大器原理与分析
电子学─放大器原理与分析
ChB1-1 MOS structure with quizzes
ChB1-2 MOS transistor with quizzes
ChB1-3 MOSFET channel formation with quizzes
ChB1-4.1 IV Characteristics with quizzes
ChB1-4.2 Example IV characteristics
ChB1-5 Channel length mod and body effect
ChB1-6 PMOSFET with quizzes
ChB1-7 MOSFET Characteristics with quizzes
ChB2-1 Operating point with quizzes
ChB2-2 Examples v2.0
ChB2-3 Self-bias and current source with quizzes
ChB3-1 biasing and amplification with quizzes
ChB3-2 Transconduction with quizzes
ChB3-3 Small signal model with quizzes
ChC1-1 , Single stage amplifiers with quizzes
ChC1-2.1 , saturation mode, CS resistive with quizzes
ChC1-2.2 , small signal, CS resistive with quizzes
ChC1-3.1 , operation, CS diode load with quizzes
ChC1-3.2 , small signal, CS diode load with quizzes
ChC1-4 , CS current load with quizzes
ChC1-5.1 , operation_CS, degeneration resistor with quizzes
ChC1-5.2 , transconductance, CS, degeneration resistor with quizzes
ChC1-5.3 , output resistance and gain, CS, degeneration resistor with quizzes
ChC2-1.1 , operation, Common gate with quizzes
ChC2-1.2 , small signal, Common gate with quizzes
ChC2-1.3 , generalized behavior, Common gate with quizzes
ChC2-1.4 , examples, Common gate
ChC2-2.1 , basics, Common drain with quizzes
ChC2-2.2 , with biasing, Common drain with quizzes
ChC2-2.3 , supply independent biasing, Common drain with quizzes
ChC3-1 , Cascode Stages, Introduction with quizzes
ChC3-2.1.1 , Cascode stages, bipolar with quizzes
ChC3-2.1.2 , Cascode stages, bipolar with quizzes
ChC3-2.2 , Cascode Stages, MOS with quizzes
ChC3-3.1 , Cascode Stages, transconductance with quizzes
ChC3-3.2 , Cascode Stages, gain with quizzes
ChC4-1 , Current Mirrors, basic concepts with quizzes
ChC4-2 , Current Mirrors, MOS, examples, no quizzes
ChD1-1.1 , Basic concepts of DA with quizzes
ChD1-1.2 , Bipolar differential amplifiers, basics with quizzes
ChD2-1.1small signal Bipolar differential amplifier with quizzes
ChD2-1.2 , half-circuit, small signal, Bipolar differential amplifier with quizzes
ChD2-1.3 , examples, half-circuit, small signal, Bipolar differential amplifier, no quizzes
ChD2-1.4 , Cascode Bipolar differential amplifier, no quizzes
ChD2-2.1 , CMOS DA small signal analysis with quizzes
ChD2-2.2 , examples, CMOS DA small signal analysis, no quizzes
ChD3-1 , DA, signle-ended with quizzes
ChD3-2.1 , small signal, DA, signle-ended with quizzes
ChD3-2.2 , gm and rout, DA, signle-ended with quizzes
ChD4-1.1 , basics, Opamp circuit as black block
ChD4-1.2 , inverting amp., Opamp circuit as black block, basics
ChD4-2.1 , general impedance, integrator, Opamp as a black block
ChE1-1.1 , Concept, Frequency responses with quizzes
ChE1-1.2,p9-13, Bode plot, Frequency responses with quizzes
ChE1-2.1 , load capacitor, passive filter with quizzes
ChE1-2.2 ,coupling cap and both, passive filter with quizzes
ChE2-1.1 , ex1-2, load in amplifier, basic frequency response with quizzes
ChE2-1.2 , ex3, load in amplifier, basic frequency response no quizzes
ChE2-2.1 , coupling input, amplifier frequency response with quizzes
ChE2-2.2 , coupling output, amplifier frequency response, no quiz
ChE2-3.1 , coupling and load in amplifier - 1, no quizzes
ChE2-3.2 , coupling and load in amplifier
http://sina.lt/fhME |
