求助:如何解决Warning?
求助:如何解决Warning?
Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
Warning: Found pins functioning as undefined clocks and/or memory enables
 Info: Assuming node "clk" is an undefined clock
虽然warning不影响下载,但看了实在想弄清楚到底为什么出这些问题.所以贴出来,请高手指教啊
谢谢了
“Info: Assuming node "clk" is an undefined clock”
因为clk是时钟资源,所以需要你定义。
方法如下:
quartus
assignment->timing analysis setting...->individual clocks...
弹出individual clocks对话框,点new添加,然后输入你的clk信息就可以了
具体说明点help。
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
