C语言经典算法之汉诺塔1
C语言经典算法之汉诺塔1
这是个汉诺塔程序,在调试的时候,输入的数字最好不要大于15,因为每大一个数
所得的结果的步骤都会多一倍。如果你有耐心等待结果的话除外。汉诺塔是在欧洲
流行的一种游戏,有a,b,c三个竿。a竿上有若干个由大到小的圆盘,大的在下面,
小的在上面,b,c都是空杆,请你把a杆上的圆盘都倒到别的杆上,或bc,在倒盘
的过程中不可以大的压小的,实例程序如下:
#include <stdio.h>
int i=0;
main()
         unsignedn;
         printf("Pleaseenter the number of discs: ");
         scanf("%d",&n);
         printf("\tneedle:\ta\tb\t c\n");
         movedisc(n,'a','c','b');
         printf("\tTotal: %d\n",i);
         getch();
movedisc(n,fromneedle,toneedle,usingneedle)
unsigned n;
char fromneedle,toneedle,usingneedle;
         if(n>0)
                   movedisc(n-1,fromneedle,usingneedle,toneedle);
                   i++;
                   switch(fromneedle)
                      case 'a':switch(toneedle)
                               case'b':printf("\t[%d]:\t%2d------>%2d\n",i,n,n);
                                                        break;
                                               case'c':printf("\t[%d]:\t%2d------------->%2d\n",i,n,n);
                                                        break;
                               break;
           case 'b':switch(toneedle)
                               case'a':printf("\t[%d]:\t%2d<----------%2d\n",i,n,n);
                                                        break;
                                               case'c':printf("\t[%d]:\t\t%2d------>%2d\n",i,n,n);
                                                        break;
                               break;
           case 'c':switch(toneedle)
                               case'a':printf("\t[%d]:\t%2d<--------------%2d\n",i,n,n);
                                                        break;
                                               case'b':printf("\t[%d]:\t\t%2d<--------%2d\n",i,n,n);
                                                        break;
                               break;
       movedisc(n-1,usingneedle,toneedle,fromneedle);
