事件处理、JavaScript 和 Ajax(3)
大多数情况下,您将需要使用提示和按钮文本来配置登录组件,如图 4 所示:
图 4. 充分配置的 login 组件 清单 5 展示了生成 所示的 login 组件的标记:
清单 5. 配置 login 组件1
2
3
4
5
6
7
8
9
10
11
12
13
14
| <ui:composition xmlns="http://www.w3.org/1999/xhtml"
xmlns:f="http://java.sun.com/jsf/core"
xmlns:h="http://java.sun.com/jsf/html"
xmlns:ui="http://java.sun.com/jsf/facelets"
xmlns:util="http://java.sun.com/jsf/composite/components/util">
<util:login loginPrompt="#{msgs.loginPrompt}"
namePrompt="#{msgs.namePrompt}"
passwordPrompt="#{msgs.passwordPrompt}"
loginButtonText="#{msgs.loginButtonText}"
loginAction="#{user.login}"
managedBean="#{user}"/>
</ui:composition>
在 中,我从一个资源包中获取了用于提示的字符串和登录按钮的文本。
清单 6 定义了 login 组件:
清单 6. 定义 login 组件1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
| <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<!-- Usage:
managedBean="#{user}">
<f:actionListener for="loginButton"
type="com.clarity.LoginActionListener"/>
</util:login>
managedBean must have two properties: name and password.
The loginAction attribute must be an action method that takes no
arguments and returns a string. That string is used to navigate
to the page the user sees after logging in.
This component's loginButton is accessible so that you can
add action listeners to it, as depicted above. The class specified
in f:actionListener's type attribute must implement the
javax.faces.event.ActionListener interface.
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:composite="http://java.sun.com/jsf/composite">
<!-- INTERFACE -->
<composite:interface>
<!-- PROMPTS -->
<composite:attribute name="loginPrompt"/>
<composite:attribute name="namePrompt"/>
<composite:attribute name="passwordPrompt"/>
<!-- LOGIN BUTTON -->
<composite:attribute name="loginButtonText"/>
<!-- loginAction is called when the form is submitted -->
<composite:attribute name="loginAction"
method-signature="java.lang.String login()"
required="true"/>
<!-- You can add listeners to this actionSource: -->
<composite:actionSource name="loginButton" targets="form:loginButton"/>
<!-- BACKING BEAN -->
<composite:attribute name="managedBean" required="true"/>
</composite:interface>
<!-- IMPLEMENTATION -->
<composite:implementation>
<div class="prompt">
#{cc.attrs.loginPrompt}
</div>
<!-- FORM -->
<h:form id="form">
<h:panelGrid columns="2">
<!-- NAME AND PASSWORD FIELDS -->
#{cc.attrs.namePrompt}
<h:inputText id="name"
value="#{cc.attrs.managedBean.name}"/>
#{cc.attrs.passwordPrompt}
<h:inputSecret id="password" size="8"
value="#{cc.attrs.managedBean.password}"/>
</h:panelGrid>
<p>
<h:commandButton id="loginButton"
value="#{cc.attrs.loginButtonText}"
action="#{cc.attrs.loginAction}"/>
</p>
</h:form>
</composite:implementation>
</html>
和 map 组件一样,login 也可以使用一个 Ajax 升级。在下一个技巧介绍 时,我将展示如何将 Ajax 验证添加到 login 组件中。 |
