中断执行后,为何没有返回到主程序中?
中断执行后,为何没有返回到主程序main()中?
我试着编了一个timer中断的小程序,当计到某一数值时可以调用一个中断,但调用中断后,为何没能返回到我的主程序main()继续执行下面的程序呢?请大侠过来看看。 #include "xparameters.h" #include "stdio.h" #include "xgpio_l.h" #include "xtmrctr_l.h" #include "xintc_l.h" #include "xgpio.h" #include "xexception_l.h" XGpio Gpio; int intc_command=0; #define timer_count 0x4000000 #define GPIO_EXAMPLE_DEVICE_ID XPAR_GENERIC_GPIO_DEVICE_ID
/* Timer interrupt service routine */ void timeinthandle(void * baseaddr_p) // { int csr; /* Read timer 0 CSR to see if it requested the interrupt */ csr = XTmrCtr_mGetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0); if(csr&XTC_CSR_INT_OCCURED_MASK) { XGpio_SetDataDirection(&Gpio, 1, 0x0); XGpio_mSetDataReg(XPAR_GENERIC_GPIO_BASEADDR, 1, \ (0x03 ^ XGpio_mGetDataReg(XPAR_GENERIC_GPIO_BASEADDR, 1))); } /* Clear the timer interrupt */ XTmrCtr_mSetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0, csr); intc_command = XTRUE; }
/* Interrupt test routine */ void InterruptTest(void) { int tmrvalue; print("-- Entering InterruptTest() --\r"); /* Initialize exception handling */ XExc_Init(); /* Register external interrupt handler */ XExc_RegisterHandler(XEXC_ID_NON_CRITICAL_INT, (XExceptionHandler)XIntc_DeviceInterruptHandler, (void *)XPAR_OPB_INTC_0_DEVICE_ID); /* Start the interrupt controller */ XIntc_mMasterEnable(XPAR_OPB_INTC_0_BASEADDR); /* Set the gpio for LEDs as output 1 is the channel used*/ XGpio_Initialize(&Gpio, GPIO_EXAMPLE_DEVICE_ID); XGpio_SetDataDirection(&Gpio, 1, 0x0); /* Set the number of cycles the timer counts before interrupting */ XTmrCtr_mSetLoadReg(XPAR_OPB_TIMER_0_BASEADDR, 0, timer_count); /* Reset the timers, and clear interrupts */ XTmrCtr_mSetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0, XTC_CSR_INT_OCCURED_MASK | XTC_CSR_LOAD_MASK ); // clear the load bit XTmrCtr_mSetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0,0x0 ); /* Enable timer interrupt requests in the interrupt controller */ XIntc_mEnableIntr(XPAR_OPB_INTC_0_BASEADDR, XPAR_OPB_TIMER_0_INTERRUPT_MASK); /* Start the timers */ XTmrCtr_mSetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0, XTC_CSR_ENABLE_TMR_MASK | XTC_CSR_ENABLE_INT_MASK | XTC_CSR_AUTO_RELOAD_MASK | XTC_CSR_DOWN_COUNT_MASK); /* Enable PPC non-critical interrupts */ XExc_mEnableExceptions(XEXC_NON_CRITICAL); //wait the interrupt to occur while(!intc_command) { xil_printf("Main Program\n"); } xil_printf("Main Program Continue\n"); /* Disable PPC non-critical interrupts */ XTmrCtr_mSetControlStatusReg(XPAR_OPB_TIMER_0_BASEADDR, 0, XTC_CSR_IN T_OCCURED_MASK ); XExc_mDisableExceptions(XEXC_NON_CRITICAL); print("-- Exiting InterruptTest() --\r\n"); } /* End user-supplied interrupt test routine */ //==================================================== int main (void) { print("-- Entering main() --\r\n"); InterruptTest(); print("-- Exiting main() --\r\n"); return 0; }
执行到蓝色部分时,会调用中断服务程序void timeinthandle(void * baseaddr_p) ,在这个程序程序 中令intc_command=XTRUE,这样就不再去执行中断了,但它却继续执行,而为什么没有退出到while((!intc_command)去执行下面的程序呢?
