搭建Harbor企业级docker仓库(5)
6.执行安装脚本
# /usr/local/harbor/install.sh
执行过程
    [Step 0]: checking installation environment ...
    Note: docker version: 17.03.1
    Note: docker-compose version: 1.16.1
    [Step 1]: preparing environment ...
    Clearing the configuration file: ./common/config/adminserver/env
    Clearing the configuration file: ./common/config/ui/env
    Clearing the configuration file: ./common/config/ui/app.conf
    Clearing the configuration file: ./common/config/ui/private_key.pem
    Clearing the configuration file: ./common/config/db/env
    Clearing the configuration file: ./common/config/jobservice/env
    Clearing the configuration file: ./common/config/jobservice/app.conf
    Clearing the configuration file: ./common/config/registry/config.yml
    Clearing the configuration file: ./common/config/registry/root.crt
    Clearing the configuration file: ./common/config/nginx/nginx.conf
    loaded secret from file: /data/secretkey
    Generated configuration file: ./common/config/nginx/nginx.conf
    Generated configuration file: ./common/config/adminserver/env
    Generated configuration file: ./common/config/ui/env
    Generated configuration file: ./common/config/registry/config.yml
    Generated configuration file: ./common/config/db/env
    Generated configuration file: ./common/config/jobservice/env
    Generated configuration file: ./common/config/jobservice/app.conf
    Generated configuration file: ./common/config/ui/app.conf
    Generated certificate, key file: ./common/config/ui/private_key.pem, cert file: ./common/config/registry/root.crt
    The configuration files are ready, please use docker-compose to start the service.
    [Step 2]: checking existing instance of Harbor ...
    [Step 3]: starting Harbor ...
    Creating network "harbor_harbor" with the default driver
    Pulling log (vmware/harbor-log:v1.2.0)...
    v1.2.0: Pulling from vmware/harbor-log
    93b3dcee11d6: Pull complete
    07d028a1dbdd: Pull complete
    208723cd598a: Pull complete
    b876b05989fc: Pull complete
    12f0e0ef448a: Pull complete
    Digest: sha256:608e10b7aaac07e10a4cd639d8848aef96daa7dd5c7ebaaf6a7ecd47f903e1f8
    Status: Downloaded newer image for vmware/harbor-log:v1.2.0
    Pulling adminserver (vmware/harbor-adminserver:v1.2.0)...
    v1.2.0: Pulling from vmware/harbor-adminserver
    93b3dcee11d6: Already exists
    6ab21236e58b: Pull complete
    f70b0efff900: Pull complete
    c5d206b5e184: Pull complete
    Digest: sha256:aba66ec90fc12fe0814cecc9f647f5d17b41395199821cc7af69db9c0fbe446c
    Status: Downloaded newer image for vmware/harbor-adminserver:v1.2.0
    Pulling registry (vmware/registry:2.6.2-photon)...
    2.6.2-photon: Pulling from vmware/registry
    007fe7635995: Pull complete
    20d63c99b572: Pull complete
    2026103b2811: Pull complete
    ab7a5be79b33: Pull complete
    11757dc5c642: Pull complete
    69ab3e15edde: Pull complete
    Digest: sha256:3cf06cdff00f48e15a5254b6d0370bcb4423dcd158e7f970dc8246893125b032
    Status: Downloaded newer image for vmware/registry:2.6.2-photon
    Pulling ui (vmware/harbor-ui:v1.2.0)...
    v1.2.0: Pulling from vmware/harbor-ui
    6ab21236e58b: Already exists
    7753f4b55df6: Pull complete
    a647b33bdf74: Pull complete
    eb30db926101: Pull complete
    204d77847826: Pull complete
    4910a0b56c59: Pull complete
    e880a4b0031f: Pull complete
    Digest: sha256:b198d8f2f59515d286bdcf06c7f99c370eb4475e2547495c3e1db8761940646b
    Status: Downloaded newer image for vmware/harbor-ui:v1.2.0
    Pulling mysql (vmware/harbor-db:v1.2.0)...
    v1.2.0: Pulling from vmware/harbor-db
    df559435c037: Pull complete
    a6310a57af5d: Pull complete
    d13d90890144: Pull complete
    b694d8967a6c: Pull complete
    a34f6cef56a6: Pull complete
    3519eec83af5: Pull complete
    34bae610e56c: Pull complete
    86a867bebd89: Pull complete
    3db2d0ac366e: Pull complete
    c0d307ee295f: Pull complete
    c5b1b404c5ee: Pull complete
    14f4a4328366: Pull complete
    c7fa77b46ec4: Pull complete
    0cbe2b5669b8: Pull complete
    Digest: sha256:c10b3555beb6d1c851ae49a4e90ef4296a1ad42bcd1a58ae97e316b034515b6e
    Status: Downloaded newer image for vmware/harbor-db:v1.2.0
    Pulling jobservice (vmware/harbor-jobservice:v1.2.0)...
    v1.2.0: Pulling from vmware/harbor-jobservice
    64bd0172d071: Pull complete
    b4f5382f226f: Pull complete
    Digest: sha256:0692648176c1c87379025b0519036b9f3f1a0eceb2646f17dd40eb143c898d5c
    Status: Downloaded newer image for vmware/harbor-jobservice:v1.2.0
    Pulling proxy (vmware/nginx-photon:1.11.13)...
    1.11.13: Pulling from vmware/nginx-photon
    d2a110a9296e: Pull complete
    Digest: sha256:9ec5644c667e87bf051e581ce74b2933d3ed469b27862534ba60ccf17b4ff57a
    Status: Downloaded newer image for vmware/nginx-photon:1.11.13
    Creating harbor-log ...
    Creating harbor-log ... done
    Creating harbor-db ...
    Creating harbor-adminserver ...
    Creating registry ...
    Creating harbor-db
    Creating registry
    Creating registry ... done
    Creating harbor-ui ...
    Creating harbor-ui ... done
    Creating nginx ...
    Creating harbor-jobservice ...
    Creating nginx ... done
    ✔ ----Harbor has been installed and started successfully.----
    Now you should be able to visit the admin portal at http://rgs.unixfbi.com. For more details, please visit https://github.com/vmware/harbor .
