iOS caf转mp3
iOS caf转mp3
#include "lame.h"
    NSURL *mp3FilePath = [NSURL URLWithString:[self getFullFilePathInDocuments"record" fileName"mySelfRecord.mp3"]];
    //sourceUrl是caf的路径
    NSURL *recordUrl = [NSURL URLWithString:sourceUrl];
    @try {
        int read, write;
        FILE *pcm = fopen([[recordUrl absoluteString] cStringUsingEncoding:1], "rb"); //source 被转换的音频文件位置
        fseek(pcm, 4*1024, SEEK_CUR); //skip file header
        FILE *mp3 = fopen([[mp3FilePath absoluteString] cStringUsingEncoding:1], "wb"); //output 输出生成的Mp3文件位置
        NSLog(@"sour-- %@   last-- %@",sourceUrl,mp3FilePath);
        const int PCM_SIZE = 8192;
        const int MP3_SIZE = 8192;
        short int pcm_buffer[PCM_SIZE*2];
        unsigned char mp3_buffer[MP3_SIZE];
        lame_t lame = lame_init();
        lame_set_in_samplerate(lame, 11025.0);
        lame_set_VBR(lame, vbr_default);
        lame_init_params(lame);
        do {
            read = fread(pcm_buffer, 2*sizeof(short int), PCM_SIZE, pcm);
            if (read == 0)
                write = lame_encode_flush(lame, mp3_buffer, MP3_SIZE);
            else
                write = lame_encode_buffer_interleaved(lame, pcm_buffer, read, mp3_buffer, MP3_SIZE);
            fwrite(mp3_buffer, write, 1, mp3);
        } while (read != 0);
        lame_close(lame);
        fclose(mp3);
        fclose(pcm);
    @catch (NSException *exception) {
        NSLog(@"%@",[exception description]);
    @finally {
        if (mp3FilePath) {
