make在执行时,需要一个命名为Makefile的文件。这个文件告诉make以何种方式编译源代码和链接程序。典型地,可执行文件可由一些.o文件按照一定的顺序生成或者更新。如果在你的工程中已经存在一个活着多个正确的Makefile。当对工程中的若干源文件修改以后,需要根据修改来更新可执行文件或者库文件,正如前面提到的你只需要在shell下执行“make”。make会自动根据修改情况完成源文件的对应.o文件的更新、库文件的更新、最终的可执行程序的更新。 make通过比较对应文件(规则的目标和依赖,)的最后修改时间,来决定哪些文件需要更新、那些文件不需要更新。对需要更新的文件make就执行数据库中所记录的相应命令(在make读取Makefile以后会建立一个编译过程的描述数据库。此数据库中记录了所有各个文件之间的相互关系,以及它们的关系描述)来重建它,对于不需要重建的文件make什么也不做。 而且可以通过make的命令行选项来指定需要重新编译的文件。
Problems and Bugs ================= If you have problems with GNU `make' or think you've found a bug, please report it to the developers; we cannot promise to do anything but we might well want to fix it. Before reporting a bug, make sure you've actually found a real bug.Carefully reread the documentation and see if it really says you can do what you're trying to do. If it's not clear whether you should be able to do something or not, report that too; it's a bug in the documentation! Before reporting a bug or trying to fix it yourself, try to isolate it to the smallest possible makefile that reproduces the problem. Then send us the makefile and the exact results `make' gave you, including any error or warning messages. Please don't paraphrase these messages: it's best to cut and paste them into your report. When generating this small makefile, be sure to not use any non-free or unusual tools in your commands: you can almost always emulate what such a tool would do with simple shell commands. Finally, be sure to explain what you expected to occur; this will help us decide whether the problem was really in the documentation. Once you have a precise problem you can report it in one of two ways.Either send electronic mail to:
bug-make@gnu.org
or use our Web-based project management tool, at:
http://savannah.gnu.org/projects/make/
In addition to the information above, please be careful to include the version number of `make' you are using. You can get this information with the command `make --version'. Be sure also to include the type of machine and operating system you are using. One way to obtain this information is by looking at the final lines of output from the command `make --help'.
以上时GNU make的bug反馈方式。如果在你使用GNU make过程中。发现bug或者问题。可以通过以上的方式和渠道反馈。 好了。开始我们的神奇之旅吧!
在执行make之前,需要一个命名为Makefile的特殊文件(本文的后续将使用Makefile作为这个特殊文件的文件名)来告诉make需要做什么(完成什么任务),该怎么做。通常,make工具主要被用来进行工程编译和程序链接。 本节将分析一个简单的Makefile,它对一个包含8个C的源代码和三个头文件的工程进行编译和链接。这个Makefile提供给了make必要的信息,make程序根据Makefile中的规则描述执行相关的命令来完成指定的任务(如:编译、链接和清除编译过程文件等)。复杂的Makefile我们将会在本文后续进行讨论。 当使用make工具进行编译时,工程中以下几种文件在执行make时将会被编译(重新编译): 1.
所有的源文件没有被编译过,则对各个C源文件进行编译并进行链接,生成最后的可执行程序; 2.
每一个在上次执行make之后修改过的C源代码文件在本次执行make时将会被重新编译; 3.
头文件在上一次执行make之后被修改。则所有包含此头文件的C源文件在本次执行make时将会被重新编译。 后两种情况是make只将修改过的C源文件重新编译生成.o文件,对于没有修改的文件不进行任何工作。重新编译过程中,任何一个源文件的修改将产生新的对应的.o文件,新的.o文件将和以前的已经存在、此次没有重新编译的.o文件重新连接生成最后的可执行程序。 首先让我们先来看一些Makefile相关的基本知识。
一个简单的Makefile描述规则组成: TARGET... : PREREQUISITES... COMMAND ... ... target:规则的目标。通常是最后需要生成的文件名或者为了实现这个目的而必需的中间过程文件名。可以是.o文件、也可以是最后的可执行程序的文件名等。另外,目标也可以是一个make执行的动作的名称,如目标“clean”,我们称这样的目标是“伪目标”。 prerequisites:规则的依赖。生成规则目标所需要的文件名列表。通常一个目标依赖于一个或者多个文件。 command:规则的命令行。是规则所要执行的动作(任意的shell命令或者是可在shell下执行的程序)。它限定了make执行这条规则时所需要的动作。 一个规则可以有多个命令行,每一条命令占一行。注意:每一个命令行必须以[Tab]字符开始,[Tab]字符告诉make此行是一个命令行。make按照命令完成相应的动作。这也是书写Makefile中容易产生,而且比较隐蔽的错误。 命令就是在任何一个目标的依赖文件发生变化后重建目标的动作描述。一个目标可以没有依赖而只有动作(指定的命令)。比如Makefile中的目标“clean”,此目标没有依赖,只有命令。它所定义的命令用来删除make过程产生的中间文件(进行清理工作)。 在Makefile中“规则”就是描述在什么情况下、如何重建规则的目标文件,通常规则中包括了目标的依赖关系(目标的依赖文件)和重建目标的命令。make执行重建目标的命令,来创建或者重建规则的目标(此目标文件也可以是触发这个规则的上一个规则中的依赖文件)。规则包含了文件之间的依赖关系和更新此规则目标所需要的命令。 一个Makefile文件中通常还包含了除规则以外的很多东西(后续我们会一步一步的展开)。一个最简单的Makefile可能只包含规则。规则在有些Makefile中可能看起来非常复杂,但是无论规则的书写是多么的复杂,它都符合规则的基本格式。 make程序根据规则的依赖关系,决定是否执行规则所定义的命令的过程我们称之为执行规则。 |
